Results 1 to 3 of 3
11-16-2016, 12:30 PM #1Junior Member
- Nov 2016
- SF East Bay
Pewter- 2001 Trans Am WS6
NEED PART! Secondary Air Injection Hose - 2001 TA,Pass side
2001 TA WS6.
The dealership says it's P/N 12562128. Can not find this anywhere.
Secondary Air Injection HOSE. There's a pipe coming up from the manifold that ends in a check valve, the hose that goes from there across the back of the engine to the air pump was hard as a rock and split near the engine end. There's a 90 close to the other end that would cause a kink if a straight hose was used, but about half way back from the check valve the hose isn't brittle and is still pretty pliable so, when the part wasn't available anywhere, I cut the brittle part off and sub'd in a piece of heater hose, but it's just taking too much heat and I can sometimes catch a wiff of rubber - not good.
If no one can help me locate this, can anyone suggest a type of straight hose that could stand up to the heat?
11-16-2016, 04:55 PM #2Junior Member
- Aug 2016
- Merrick,NY
- 2001 WS6
Did you try rockauto?
Sent from my iPhone using Tapatalk
11-16-2016, 05:33 PM #3Junior Member
- Nov 2016
- SF East Bay
What is the secondary air injection system
By Street Fighter in forum General HelpReplies: 13Last Post: 03-21-2015, 08:31 AM -
Help: Secondary Air Injection
By FirehawkM6 in forum External EngineReplies: 5Last Post: 10-15-2012, 09:17 AM -
Help: secondary air injection
By mvinson in forum General HelpReplies: 4Last Post: 06-09-2012, 05:53 PM -
99 trans am secondary air injection
By MattB75 in forum External EngineReplies: 3Last Post: 01-27-2008, 07:29 PM -
Replacing the Pass Side AIR Sys Hose
By T/Aboo in forum General HelpReplies: 6Last Post: 10-10-2007, 04:57 AM
