Thread: 295 tires rubbing!
08-13-2016, 09:09 AM #1Junior Member
- Jan 2016
- Abilene, Texas
Red- 2000 Trans Am
295 tires rubbing!
I have recently got new wheels and tires for my car. And once I put them on the guys told me that the back end rubs a little bit but I had no idea why. I've put the car on a lift and looked where its rubbing and its on the inner tire and I can't seem to find the problem! if you guys could give me any input/advice that'd be awesome!
08-13-2016, 09:16 AM #2
Inner tire as in on the tread, or on the side wall?
Pics?
Sent from my SM-G900V using TapatalkBoost gets you laid, unless your name is Jon.
08-13-2016, 09:31 AM #3Junior Member
- Jan 2016
- Abilene, Texas
Red- 2000 Trans Am
The inner sidewall I believe. Here are some pictures of whats going on.
https://gyazo.com/47c7eedeab9ae8623ab732ff82ddc392
https://gyazo.com/0a241035c8f45fd0b532ad5919f659c4https://gyazo.com/fcff5adda0979f9053d5141a8a021071
The links will send you to the pictures. I was having trouble getting them on the site.
08-13-2016, 12:19 PM #4
08-13-2016, 01:00 PM #5Junior Member
- Jan 2016
- Abilene, Texas
Red- 2000 Trans Am
I was thinking it was the bump stops but I wasn't for sure. The back only rubs when I'm either turning kinda sharp or accelerating hard when my back end squats down is when I rub the worst.
The wheels are front 18x9.5 and rear 18x10.5.. The tires are 295/40/18 (back) and 275/40/18 (fronts)
And I'm not sure if I have enough room or not. My tires aren't ridiculously tall so I have enough room to run spacers
https://gyazo.com/2a538c18cf5d43a39e9ef193b9f6a02e
https://gyazo.com/3014788797be01cfc9c33b794702f874
https://gyazo.com/b938874aeb1bd911ec754faad404b816
https://gyazo.com/d5b77dd7cd9acef79aa7d23b2ffe29fe
Here are some more pictures of the rears.. It cuts it close but I'm still not sure if I have room to run spacers.Last edited by TheRed2kTA; 08-13-2016 at 01:04 PM.
08-13-2016, 02:38 PM #6Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I run the same size on the rear also. It's definitely your bump stops rubbing. Take the wheels off and grab a grinder and just grind down the sides of the bump stop so they are even with edge of the wheel well. Probably a good time to replace yours since they look pretty rotten. You can get regular rubber or poly replacements. Sam strano website has some Jeep poly ones that fit our car. That way you get all new hardware. The rubber replacements you can find are just reproduction stuff without all the hardware. Just depends on the kind of ride you want.
08-13-2016, 04:17 PM #7Junior Member
- Jan 2016
- Abilene, Texas
Red- 2000 Trans Am
I took off my wheels a little earlier today to see if anything was showing.. And it wasn't my bump stops actually it was like the inner finder was poking inwards to much so I took a mallet and pushed it out a little bit, then went and drove my car and it's perfectly fine now. No rubbing on corners or hard accelerations!
08-13-2016, 05:48 PM #8Senior Member
- Aug 2007
- Greensboro, NC
Glad you figured it out. Easy fix. Your tire must run wider then most 295. That's not usually a issue on TAs until you get into 305s or 315s.
08-13-2016, 07:38 PM #9Junior Member
- Jan 2016
- Abilene, Texas
Red- 2000 Trans Am
Yea. I've never seen this being a problem for our cars.. But I'm glad it wasn't anything to big and it was an easy fix. And yea I figured once I hit 305+ sizes I would start having problems but seems that it was just part of the cars body and pushed in a little to far I guess
Help: 18x9.5 tires rubbing
By bhunter0830 in forum Firebird / WS6Replies: 5Last Post: 05-03-2013, 04:34 AM -
new tires rubbing rear lcrs
By 28Marcos in forum Suspension and HandlingReplies: 23Last Post: 01-07-2011, 03:58 PM -
Help: front tires rubbing fender well
By dbrichrider33333 in forum Firebird / WS6Replies: 9Last Post: 06-19-2010, 11:21 AM -
Rims/Tires Rubbing Inner Well
By Castle in forum Wheels and TiresReplies: 16Last Post: 10-21-2007, 09:39 PM -
tires rubbing on back fender
By fuelslut in forum Suspension and HandlingReplies: 3Last Post: 01-12-2006, 11:10 AM
