    Member bhunter0830's Avatar
    Apr 2012
    Fishers (Indianapols), IN
    2009 Pontiac G8 GT
    18x9.5 tires rubbing
    Recently installed BMR lowering springs, Founders Performance LCA's with relocation brackets, adj PHB and KYB struts. I now get fender rub when going over bridges and dips in the road at high speed. I'm guessing I need taller bump stops. Is that a correct assumption or should I be looking at hammering the fenders? If I do need bump stops, any suggestion as to what and where to purchase?
    2000 Trans Am - Sold
    BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, American Racing Torq Thrust 2's, Founders STB, LCA's, LCA Relocation Brackets, Adjustable PHB, BMR Lowering Springs. Deleted AIR & EGR & Tuned By Frost. 1 of 23 MRM with options.
    2009 Pontiac G8 GT Stock
    Junior Member The Machinist's Avatar
    Nov 2012
    washington
    2001 Camaro SS SLP# 2646
    Like inner fenders? Or fender lip?
    Apr 2012
    2009 Pontiac G8 GT
    Outer fenders. You can see where it rubs on the tires. Not horrible but enough that you can hear and feel it. First road trip other than around town.
    Nov 2012
    washington
    I had that problem until I got my fenders professionally rolled. Never had a problem since. You could try doing it yourself but if your not REALLY careful you'll crack the paint/distort the quarter panels
    Is it only on one side, or both?
    Apr 2012
    2009 Pontiac G8 GT
    Both. New bump stops are in. Will install when back from Florida.
  1. 295 tires rubbing!
    By TheRed2kTA in forum Wheels and Tires
    Last Post: 08-13-2016, 07:38 PM
  2. new tires rubbing rear lcrs
    By 28Marcos in forum Suspension and Handling
    Last Post: 01-07-2011, 03:58 PM
  3. Help: front tires rubbing fender well
    By dbrichrider33333 in forum Firebird / WS6
    Last Post: 06-19-2010, 11:21 AM
  4. Rims/Tires Rubbing Inner Well
    By Castle in forum Wheels and Tires
    Last Post: 10-21-2007, 09:39 PM
  5. tires rubbing on back fender
    By fuelslut in forum Suspension and Handling
    Last Post: 01-12-2006, 11:10 AM
