08-12-2016, 08:39 PM #1
2010 1500 silverado 5.3 oil pressure problems!
So I have had my 2010 1500 silverado 5.3l for about a year now. It is currently sitting at or around 100k with me driving a little over 20k. I started having issues with my low oil pressure warning coming on and warning me to shut the engine down. Well after pulling over and checking engine oil level as well as listening to the engine itself I decided to do some research. There is a screen that goes inside the block before the sending unit. Which I pulled on Tuesday to check it out. It is located on the driver side behind the intake manifold. The tiny screen was so clogged up with debris and whatever else that it was not allowing the pressure to get through to the sending unit. I pulled the screen replaced the other ring and spray it down with carb cleaner and the air hose. Cleared all the codes. Oil pressure returned to normal, and I've not had a problem since. I will go in next week take pictures and post them up if anybody has any questions or concerns I will be happy to help. Apparently this is a common issue with the 5.3 in multiple vehicles. Btw you do not have to take the damn intake manifold off to pull the sending unit!!
Sent from my SM-G920V using Tapatalk
08-14-2016, 09:49 PM #2
What kind of "debris"? You need to be wary if you have a DOD (displacement on demand) 5.3. They eat cams. Might want to have your oil sent off to someone like blackstone labs to see how the motor is wearing.
08-15-2016, 07:56 AM #3Spaz is My Mentor
^^^this!!!!
08-17-2016, 07:23 PM #4
It wasn't crazy debris just looked like normal wear and tear. Co sideline who knows the last time that fine screen had been replaced anyway. It looked more to be engine sludge to be honest. I have seen on some silverado forums where some guys has pulled those filters and they had chunks and filings of metal in them. But I do plan on sending off a sample to see what I get back, I am kind of interested to see what the results will show.
08-17-2016, 07:27 PM #5
I also plan on having the DoD tuned out I have talked to several techs at the dealership and they have told me the early 5.3 had huge issues with the early set ups.
08-20-2016, 03:44 AM #6Senior Member
- Apr 2008
- Madison, WI
If it sludge, then you are not changing you oil enough.
-------------------------------------Kooks 1 7/8" race headers, Kooks ORY, Borla catback, Nitto 555R, LS6 intake manifold, Shaner S3 ported stock throttle body, SLP lid, smooth bellows, JAAM Ram Air kit, Elite Engineering catch can, LS6 valley cover, EGR and AIR deleted, Frost tune, and Simpson Racing child car seat in the back. 13.2 @ 108MPH
06-23-2019, 02:49 PM #7Junior Member
- Jun 2019
- US
Regular oil changes help! I see way to many of these truck with nasty engines from lack of oil changes!
Sent from my SM-G930V using Tapatalk
Help: 2005 Silverado 1500 glove box latch broken...
By KahanaReef in forum GM TrucksReplies: 3Last Post: 07-29-2013, 01:29 PM -
For Sale: 2007 Silverado 1500 LT Ext Cab GMT-900
By 02convertibleT/A in forum Vehicles For Sale / TradeReplies: 11Last Post: 07-25-2011, 05:00 AM -
2000 Chev Silverado 1500 Noises, NEED HELP
By mammoth713 in forum GM TrucksReplies: 6Last Post: 11-10-2010, 04:41 AM -
my new 98 Silverado 1500
By 02convertibleT/A in forum GM TrucksReplies: 26Last Post: 01-22-2010, 04:13 PM -
06 Silverado 1500 HD CrewCab LT FS
By sercastiK in forum Western MembersReplies: 8Last Post: 07-12-2009, 03:29 PM
