    Jul 2016
    MI
    2002 Avalanche ls1 swap cranks but no start
    I have swapped a ls1 with 243 heads 212/218 .522/.529 114 Lsa cam from comp cams stock bottom end msd coils and a set of longtube headers my phone was tuned by frost... there's 60 psi fuel at the rails used a noid light on the injectors there pulsing it has spark it's throwing no codes all the grounds are good it cranks but will not start
    Does it try to fire at all? Sounds like maybe no spark. Easy test is to hook a timing light up to any of the wires to see if it flashes.
    Jul 2016
    MI
    It has spark on all cylinders it's tried to fire twice now in the last week but won't last night I checked the rockers and they were pretty loose so I got em to spec tried to start it up and so e flames came out of the exhaust but it wasn't a loud pop like a backfire
    crank and cam sensors hooked up?
    Jul 2016
    MI
    Everything is hooked up and sensors are good
  1. Help: Engine cranks but won't start
    By cascade in forum General Help
    Last Post: 08-21-2025, 05:55 PM
  2. Sometimes cranks but doesn't start
    By Mrmowerguy in forum General Help
    Last Post: 03-07-2011, 05:59 PM
  3. Question: 1995 TRANS AM cranks but won't start
    By 1995TRANSAM in forum General Help
    Last Post: 02-22-2009, 03:11 PM
  4. another ls1 camaro cranks no start question
    By ssscamaro in forum General Help
    Last Post: 10-16-2006, 09:24 PM
