02-21-2009, 08:17 PM #1Junior Member
- georgia
black- 1995 Pontiac
1995 TRANS AM cranks but won't start
Can anyone help!!! I recently bought a 1995 Trans AM the previous owner told me the optispark was bad so I replaced it. Tried starting with no luck checked wiring and replaced plugs still would not start. Checked fault codes showed 41 and 42 so followed trouble shooting guide for those problems came down to bad ignition coil module. Checked for spark before I replaced it, had spark but intermittent replaced module and coil now still won't start and have no spark and no fault codes troubleshooting guides says bad distributor but it is new. help please!!!
02-22-2009, 08:53 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't know if this will help, but some good info/diagram: http://shbox.com/1/4th_gen_tech2.html#opti_test
02-22-2009, 12:07 PM #3Senior Member
- Apr 2008
- Madison, WI
are you checking spark at the coil wire or at on of the plug wires?
02-22-2009, 01:38 PM #4Junior Member
- georgia
black- 1995 Pontiac
I am checking the spark off of a plug wire one other thing I discovered was their is a translator box attached to several of my wires including my ignition control module I have no idea what it is or what it does I just took the lid off and found it labled as translator.
02-22-2009, 03:11 PM #5Senior Member
- Apr 2008
- Madison, WI
that box must be sliced into the ignition control module, correct? It might be for a remote start or some sort of security system. It could be causing your troubles. I'd start be removing that crap and putting the wiring back to the way the factory did it.
Help: Engine cranks but won't start
By cascade in forum General HelpReplies: 22Last Post: 08-21-2025, 05:55 PM -
Help: 2002 Avalanche ls1 swap cranks but no start
By ussoldier517 in forum LSx Retrofit and SwapReplies: 4Last Post: 07-30-2016, 03:18 PM -
Sometimes cranks but doesn't start
By Mrmowerguy in forum General HelpReplies: 18Last Post: 03-07-2011, 05:59 PM -
another ls1 camaro cranks no start question
By ssscamaro in forum General HelpReplies: 17Last Post: 10-16-2006, 09:24 PM
