Results 1 to 2 of 2
06-04-2016, 11:46 AM #1Member
- Woodbridge, VA
Navy Blue Metalic- 1999 Z28 Convertible
Puddle in rear - didn't know abut the drains - pictures inc
So after a REALLY heavy rain, I found both sides of the rear seats filled with water. Upon investigation (about 2 minutes) I discovered the side drain plugs. There was actually standing water inside the rear quarter panel.
If you dont't already know, all you have to do is put the top 1/2 way down (1st picture), stick your hand between the top mechanism and the quarter panel (second picture), and push your finger into the drain (3rd picture). There was at least 2 gallons of water on the rear floor, It'll take some time to dry out. may be time for new carpet and padding.
06-04-2016, 04:06 PM #2
Yikes! As long as you get it all dried out fairly quickly you should be ok. Get some fans on it to move the air over the carpet.
Help: Battery Drains When Engine is Hot
By Loser in forum External EngineReplies: 24Last Post: 08-19-2013, 04:48 AM -
rear hatch fix didn't work
By rigdoctormark in forum General HelpReplies: 18Last Post: 12-06-2011, 01:32 PM -
305 Block Drains
By pajeff02 in forum Classic MuscleReplies: 6Last Post: 08-25-2010, 06:57 AM -
where's the thread on rear end pictures???
By allbaugh_04 in forum Camaro / SSReplies: 3Last Post: 05-23-2007, 05:29 AM -
Electrical problem: Battery drains down
By Larry in forum General HelpReplies: 0Last Post: 09-20-2005, 11:46 AM
