Results 1 to 19 of 19
Thread: rear hatch fix didn't work
03-04-2006, 12:00 PM #1
Has anyone tried the rear hatch fix on install university.com I tried it and used the smaller c 141 springs and it doesn't fly open like everyone says. It releases better but not the fly open and hit you in the head action that was implied.
03-04-2006, 03:28 PM #2
It's not supposed to fly open...the spring mod is so you only have to push the button once to open the trunk..instead of pushing the button and the trunk only pops partly open.
03-04-2006, 05:02 PM #3
well on i was reading on ls2's site and a few on there claim "it nearly took my buddies head off when it flew open" etc. etc. I thought it was bs.
03-04-2006, 05:42 PM #4Member
- Virginia Beach, VA
Red- 2000 SS
it was...
03-04-2006, 06:08 PM #5Junior Rocketeer
- Sep 2005
- Russiaville, Indiana, United S
Sunset Orange- 2001 Z28
No, you're not alone. Mine doesn't open the first time either.
I think my problem may be a weak strut. I'll replace it one of these days and maybe it'll work right.
03-04-2006, 06:50 PM #6
If you had brand new struts, it might come open harder. But otherwise, that modification just eliminates the annoyance of having to hit the trunk release button while pulling up on the hatch.
03-04-2006, 09:38 PM #7I did the mod and have new trunk stuts and it doesn't "fly open"....I push the button and it pops open about a 1/2 in. above the latch and then rests on the latch.
Originally Posted by rigdoctormark
03-05-2006, 01:14 AM #8
One of the first mods I ever did - got tired of having to hit the release button multiple times while pulling up on hatch.
The hatch will NOT spring open with any great force with these springs - it will, however, pop open enough to properly clear the latch as it should have been from the factory.
03-05-2006, 05:37 AM #9Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Sorry, but NO spring is going to make that heavy ass hatch fly open fast enough to hit somebody in the head. It's too damn heavy.
03-05-2006, 05:50 AM #10NecctionGuest
After doing the mod mine cleared the latch on first hit of the button for about a month. Since then its been pretty much back to the original bs.
03-05-2006, 10:17 AM #11Are the struts still good? Try putting a new piggy back spring on the latch and also adjust the rubber bumbers on the hatch.
Originally Posted by Necction
03-05-2006, 12:42 PM #12Member
Red- 2000 SS
I did the mod with the "first" spring the post said to use, and it worked for a while.
I then went with a heavier spring, and it works as advertised - one hit of the button, it releases and the hatch pops up about an inch (like it's supposed to).
If you want the hatch to fly up (I assume to fully opened position), you need some sort of super strut.
03-05-2006, 08:28 PM #13Member
- Burlington, NC
Black- 2000 Camaro SS
I put a heavy piggy back spring on mine several years ago (It was one of the first mod that I did) and it has worked like a charm ever sense. There is no way that the hatch is going to pop up and spring open like a spring board nor should anyone want it too. As heavy as the hatch is, should in really pop open, that sudden stop at the top of opening would not be very good on the frame work. I'm very happy with the hatch popping open about an inch so that it can be raised. Push the button and it pops open every time with the spring mod. Just exactly the way it is suppose to. The factory should have done what we had to do for them. Anyway, I did the spring mod many, many moons ago and I am happy with the way it works.
03-07-2006, 11:43 AM #14Junior Member
- Jan 2006
- Michigan
Red- 02' Z28 M6
Originally Posted by Hurley711
Sounds like a job for MythBusters!!!!!! I bet they could get it to take a head off.....muhaaa!!!!!
03-08-2006, 06:18 PM #15Junior Member
- Mar 2006
- Tennessee
black- 1999 Pontiac Trans Am
The instructions call for a "5/8" diameter x 2.5" long spring".
I think that come in different rates of pull, or pressure, or tension, or some kind of measure.
Does anyone know what specific spring works for this repair, or exactly where one can buy this spring? I have been fighting this issue since the car was new. Thanks for any help.
03-09-2006, 01:10 PM #16
I'm gonna have to buy a really thick spring w/ awesome tension and some "Super Struts" and wait for that glorious moment when someone get's to close...SMACK!!!
03-14-2006, 03:23 PM #17
just did this like 3 minutes ago and al it took was 3 minutes ...i'm so happy, my hatch actually opens like it should now.
03-16-2006, 04:21 PM #18
My 98 Camaro always opened on the first try-never had an issue for the 4 years that I owned it. Then I traded it in on the 2002 and it hasn't really worked perfectly. I've lubed it with some white lithium grease and that helped. It still works right about half the time. I've seen these "poppers" for street rods that pop the shaved door handle hotrod doors open when you hit the remote-always wanted to try that on the hatch. There is a type that doesn't require a hole drilled,just two sided taped on. If anyone is interested I will look for the ad in the street rod magazines.
12-06-2011, 01:32 PM #19
All you need is a piggyback spring to "help" the existing spring. Go to the hardware store and get a #21 spring and piggyback it over the existing spring. It will take some massageing, but you can make it work. Now mine opens first time every time. About an inch. Which is better than having to hit it five times!
Puddle in rear - didn't know abut the drains - pictures inc
By Neil in forum ConvertibleReplies: 1Last Post: 06-04-2016, 04:06 PM -
Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
By NAVYGSE1 in forum General HelpReplies: 3Last Post: 12-20-2011, 01:07 PM -
Help: hatch release still won't work
By mdcrabbie in forum Camaro / SSReplies: 14Last Post: 02-17-2009, 10:41 PM -
Sara's casting didn't work...
By Mr. Luos in forum Almost Anything GoesReplies: 20Last Post: 10-31-2008, 07:08 PM -
Things didn't work out for us...
By DrMilhouse in forum Almost Anything GoesReplies: 14Last Post: 09-13-2006, 02:41 AM
