Thread: y-pipe
    Feb 2008
    jupiter fl.
    2000 trans am
    y-pipe
    i know theres prob a sticky but whats the better off road y-pipe for ws6 that will not hit the floor board i have a pasesetter ory and lth now i think someone said tsp had the best clearance
    That sounds right to me, but not 100% on this.
    Member DarrenWS6's Avatar
    May 2015
    Blossburg, PA
    Silver Metallic
    2000 Trans Am WS6
    I would say Kooks and American Racing would be the better quality ones out there with most likely better fitment. I have a TSP Y pipe waiting for my LTs and held in hands I feel it is garbage. But its only $150 new, so you get what you pay for. As far as Y pipe banging I can not answer that but I will be putting it in the car when I get the other stuff around.
    2000 Trans Am WS.6 M6
    SLP lid & bellow w/ K&N, GMMG catback w/ Corsa Clones, UMI SFC, UMI Adj. Panhard, UMI Adj. TQ arm w/ relocation kit, QTP Longtube headers ORY, LS6 intake, EGR/A.I.R delete.
    Eibach prokit, Bilstein HDs, Nitto NT555s, skip shift elim, whiteface overlays, 20% tint, matte black decal/overlays
    YouTube.com/DarrenWS6
    Quote Originally Posted by jodmari View Post
    There is a hanger you can buy that goes around $50. Look for Mufflex Y Pipe hanger, part # MufflexBS-3. WS6store has it.
    To solve mine I just had them weld the Y pipe in the position (minus the at the collector) and it hasn't bang my floor boards yet.
    Feb 2008
    jupiter fl.
    2000 trans am
    i have the pasesetter lth and there y pipe tryed that mufflex hanger still hit,so i put a piece of a tail pipe hanger (rubber) in between the pipe and floorboard where its the closest now it just rumbles because there no space between the pipe and floor ,so im hoping with a different pipe that takes a little different route like tsp would slove this
    Replacing old worn out motor mounts with new polyurethane mounts will sometimes gain additional exhaust clearance.
    Feb 2008
    jupiter fl.
    2000 trans am
    is there anyone that sells them new allready in the clam shell,
    Nope it's not hard to do them. Drill 3 rivet out, enlarge to new bolt size. If the oem rubber doesn't come out apply a heat gun to warm them up and they will pop out.
    It takes longer to get them out then to replace the rubber with the poly.
    ^^ This. The actual swap is simple. Getting the mounts out and then back in is a chore.
    Junior Member mrbvlo's Avatar
    Feb 2007
    Sneads Ferry, NC
    Pewter Metallic
    2000 WS6 Formula
    I've read where a member wrapped a black rubber "tie down strap" around the Y pipe where it was hitting the floor and that helped. Apparently the rubber didn't melt and it lasted for over 2 years.
    2000 WS6 Formula, 6 spd, stock
    ^^ Can't say that I would recommend trying this.
    Apr 2014
    Poly engine mounts and ARH y-pipe here. No hitting at all, even if i try to push up on the y.
  1. For Sale: Bassani y-pipe and cat delete pipe
    By Soltakr in forum Parts For Sale / Trade
    Last Post: 08-07-2008, 08:32 PM
  2. H pipe Vs. X pipe (You Make the choice for me)
    By 180ls1 in forum External Engine
    Last Post: 10-26-2007, 07:38 AM
  3. CHEAP!!! Stock Y-Pipe, Off-road Y-pipe, stock suspension
    By Black99Z28 in forum Parts For Sale / Trade
    Last Post: 06-22-2007, 09:42 AM
  4. h pipe or streight pipe
    By rice burner in forum GTO
    Last Post: 05-08-2007, 04:20 PM
  5. headers with x-pipe or y-pipe?
    By BlackTA00 in forum External Engine
    Last Post: 12-13-2005, 04:43 PM
