Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Member 180ls1's Avatar
    San Diego (Poway)
    1998 Firebird Formula WS6
    H pipe Vs. X pipe (You Make the choice for me)
    What setup would you all run? I am going to make a custom dual exhaust for my 1999 ls1 camaro. I will be running bullets and the exhaust will go out the back. My dilema is i love the sound of an h-pipe but i would like the power of an X-pipe.
    How much power would i gain from a x over an h??????
    My car is a daily driver with stock cats and manifolds and i wont change the manifolds because i live in california . I just need to know how much power i would gain with the x pipe setup and what your personal opinions are
    Marylandistan
    2001 Trans Am (sold)
    H pipe. What'll you lose? 3hp?
    San Diego (Poway)
    Quote Originally Posted by INMY01TA View Post
    Ya that is what i was thinking and it is not worth the extra $50 for an x pipe but i want to do it once and do it right.
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    i would go X just because H reminds me of a mustang... and ive never seen or heard of a trans am or camaro with an H.
    FLW Missouri
    The gains of an X over an H are minimal.
    It comes down to which one you want: Do you want the extra 2-3 hp OR a better sounding exhaust note?
    And an H pipe on an LS1 sounds MUCH different than a mustang.
    I personally went with an H pipe,magnaflow high flow cats, and 10 series Flow master race mufflers, because I wanted a deep and clean exhaust note.
    I am VERY satisfied with how mine sounds, and if it cost me a few HP so be it.
    Go to some get togethers and listen to everyones ride, then make up your mind.
    Scott
    2000 SS Arctic White (only 32k on the clock).
    Lid,ASP U/D Pulley,LT's,Custom H-PipeTD's , FlowMaster 10 series,MagnaFlow High Flow Cats,LS6 intake, P/P TB,STB, SFC's,LCA's & PHB,Stall comming...
    NeW YoRk
    2001 ws6
    x all the way
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    go true duals
    screw a crossover pipe.
    00 Z28 M6 T-tops
    00 SS A4 T-tops (Sold)
    99 Corvette M6 (Sold)
    98 Z28 A4 Coupe (Sold)
    98 Z28 A4 T-tops (Sold)
    Marylandistan
    Quote Originally Posted by b.lee View Post
    go true duals
    Why?
    Marylandistan
    H and X pipe are considered true duals.
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    I would think that an X pipe might make it easier to get more clearance. I know with the way mine is setup I have had no scrapping problems at all.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    go true duals
    That doesn't make sense.
    Junior Member AF1Strider's Avatar
    albuquerque
    1998 Camaro SS
    ive been thinking getting a X pipe and getting rid of my ORY, my question is where can i find a X pipe or H pipe that is made for a LS1?
    Blue
    2002 Z28 Camaro M6
    You can get one made at a good muffler shop. Not sure how the rest of the exhaust will do with it though, but I would think most good places could fab something up for you.
    Tulsa
    98 trans am
    go true duals
    .........................wtf?
    Arizona
    Quote Originally Posted by AF1Strider View Post
    Bassani makes the only real dual exhaust system for these cars that uses an X pipe setup in the system if thats what you are after. Otherwise it's going to be custom for cars like these.
    I prefer the X-pipe for the simple reason that it's been shown for years to produce more power over the entire rpm curve,,,,you may be talking 2-3 HP but it's 2-3 HP over the entire curve,,,thats more important than peak numbers that so many put emphasis on.
    I have tried both H and X pipes on my Chevelle and I have found no sound difference between the two.
    I currently use Dr Gas X pipes. If you want to get picky, you can tell them specifics about your car and they actually custom make the X for you, tailored to your particular engine, they can change the diameter of the hole, the shape, the position etc.. etc...where the pipes intersect to accomplish different things. I have found them worth a few ponies.
    albuquerque
    1998 Camaro SS
    ok thanks for that info on where to get X pipes. ive been thinking about it, i just didnt know where to look.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    HAve you forgotten about the most popular dual exhaust for Fbodies there is? TSP. It may be dumped but is still true duals.
    I have an x and have a friend with the same exhaust with an H, our cars soud VERY different. Both 2.5 inch duals, both with headers, both with 1 chamber flows, only his has an H and I ahve an X. I am VERy jealous of the low rumble he has
    Arizona
    Quote Originally Posted by oneBADDz View Post
    No I left them out on purpose,,,,,,just kidding, actually I'm not a big fan of that type of setup on a street car. It may be popular with the kids but I don't care for it. First of all, these Fbodies are not designed originally with that type of system in mind, with no floor pan clearance under the back seat the mufflers and pipes in general just hang too low,,,,and looking from behind the car it just looks like there is something ready to fall off. You just can't tuck it in there tight enough to keep it out of sight. These newer 4th gens are just too nice of a car to go doing something like that to,,,,just my opinion but if it's what you guys like, then more power to ya.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    I understand your reasonig, and I personally don't care for dumps either. to say that bassani makes the only ones just cause you don't like the others is alittle misleading though
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    Quote Originally Posted by HowdyZ_28 View Post
    Scott
    good set up, i only run the 10 series mufflers, and i love how they sound with an H pipe
  1. For Sale: Bassani y-pipe and cat delete pipe
    By Soltakr in forum Parts For Sale / Trade
    Last Post: 08-07-2008, 08:32 PM
  2. y pipe xpipe or H pipe?
    By 99w69kitt in forum External Engine
    Last Post: 04-30-2008, 05:50 PM
  3. CHEAP!!! Stock Y-Pipe, Off-road Y-pipe, stock suspension
    By Black99Z28 in forum Parts For Sale / Trade
    Last Post: 06-22-2007, 09:42 AM
  4. h pipe or streight pipe
    By rice burner in forum GTO
    Last Post: 05-08-2007, 04:20 PM
  5. headers with x-pipe or y-pipe?
    By BlackTA00 in forum External Engine
    Last Post: 12-13-2005, 04:43 PM
