Results 1 to 2 of 2
Thread: High Beam Fuse?
    Member herculesrider1's Avatar
    TX
    '00 TransAm RamAir WS6 M6
    High Beam Fuse?
    Does anyone know if there is a fuse for the high beam lights and if there is, where exactly it would be? The high beams have never worked on this car, but since moving to Texas, in order to get it inspected, I have to have high beams. Any help would be greatly appreciated!! Thanks.
    There should be a fuse (and possibly a relay) in the underhood electrical box, just behind the driver side headlight. There are also fuses at the end of the dash panel on the driver side that you can access with the door open. Our car is stowed for the winter or I would provide you with the numbers.
  1. High beam headlight not lighting even though it has power
    By mellor_21 in forum Stereo and Electronics
    Last Post: 03-10-2013, 01:25 PM
  2. Cheap High Beam Dimmer Switch Mod ...
    By Mecinoid in forum General Help
    Last Post: 05-16-2009, 11:08 AM
  3. No High or Low Beam Lights
    By vettehead in forum General Help
    Last Post: 05-28-2007, 01:59 PM
  4. High beam headlights dont work?
    By pilot13blackcat in forum General Help
    Last Post: 04-14-2007, 09:55 AM
  5. Replies: 2
    Last Post: 07-03-2006, 10:00 AM
