12-06-2012, 10:18 AM #1Junior Member
- Aug 2010
- SLC
Blue/Green- 2001 WS6
High beam headlight not lighting even though it has power
I have a weird problem.
TL;DR - Have power to the headlight connector but the headlight still won't light up, even though it lights from the other side's connector
I tried to replace my high beam on my 01 WS6. The socket that my driver's side high beam connects to was really corroded so I sprayed some pb blaster in it to clean it up a bit. Tried the new headlight and it didn't work, so I tested the headlight on the passenger side's socket and it lit up. So the bulb is good. I checked the corroded socket with a voltmeter and it had power.. but the headlight won't work when plugged in to it. I figured it had to be something to do with the corrosion in the socket so I cut the wires going in to it and checked them on it and it still won't light. I rechecked the wires with the voltmeter, still had power, and rechecked the bulb with the passenger side's socket, still lit up.
I'm at my wit's end. I figure there's something simple here that I'm missing, but I can't figure it out. Can anyone help?
12-06-2012, 09:01 PM #2
The ground is where I would look. That is usually the problem. Beyond that, I wouldn't know.
12-07-2012, 12:33 PM #3Junior Member
- Aug 2010
- SLC
thanks for the help but I got it. It was something to do with the prongs from the headlight not conducting electricity. After I plugged it in like 7 times it finally came on and has worked since.
12-08-2012, 03:07 PM #4
That was what I was just gonna suggest. The plugs on our cars are weird sometimes. You have a problem, unplug and replug a couple times. Had that happen on the fuel injectors once that was memorable. I took out the intake, put it in, it threw a code. I unplugged and replugged til it stopped throwing codes.
01-17-2013, 06:20 AM #5
it is possible that you have or had corrosion inside the prongs. After plugging the headlight on and off you finally made good contact. If it happens again I will suggest to replace the plug.
03-10-2013, 01:25 PM #6Senior Member
- Feb 2006
- Orange County, NY
To help protect it from future corrosion put some dielectric grease on the connections.
High Beam Fuse?
By herculesrider1 in forum Firebird / WS6Replies: 1Last Post: 01-02-2016, 03:18 AM -
Headlight (low-beam) question.
By SS Camaro UK in forum General HelpReplies: 4Last Post: 07-05-2012, 10:24 AM -
Low beam headlight bulbs...
By Mr_Rich in forum Firebird / WS6Replies: 6Last Post: 12-28-2011, 06:33 PM -
No High or Low Beam Lights
By vettehead in forum General HelpReplies: 0Last Post: 05-28-2007, 01:59 PM -
High beam headlights dont work?
By pilot13blackcat in forum General HelpReplies: 2Last Post: 04-14-2007, 09:55 AM
