Results 1 to 19 of 19
Thread: High idle issue
09-13-2015, 07:47 PM #1
- Sep 2005
- Illinois
blue- 1970 Chevelle
High idle issue
Ive got a 1998 Z28 and it has a high idle problem ive been fighting for some time. Sometimes i will start it and it will rev up for 2500-3000 RPM and just stay there. Other times i may start it and it will run normal for a few minutes then slowly start to creap up higher and higher till its around the 2500-3000 point again. I had been advised from other forums it was a vacuum leak so i replaced the main vacuum lines that go to the PCV valve and the rubber 3-way connector thats on the back of the intake as well as the hoses gong to and from that connection. I also took the intake off and found the plug that the MAF sensor plugs into to be loose so i siliconed it to the intake as well. When i put the intake back on i put new gaskets on it also. After getting it all back together i started it and it was excatly like it was before. I then took carb cleaner and sprayed it around the intake and vacuum lines and the throttle body and saw no fluctuation in the way it was running. Im at a loss on it at this point. Anyone here have any ideas for me?
Thanks in advance.
09-13-2015, 10:04 PM #2
Have you checked the IAC yet? I had this issue when I replaced my throttle body. The IAC o-ring broke and I didn't know it. Got a new o-ring and it solved the problem.
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
09-14-2015, 03:26 AM #3
It does sound like the IAC (Idle Air Control Valve) may be acting up. Could need cleaned or it may have an issue and is hanging up. Any excess air into the engine will idle it up, so also check your PCV hoses, especially where it crosses around the back of the engine from the driver side to the passenger side and also the hose between the intake and the PCV valve.
09-14-2015, 05:29 AM #4
High idle issue
just remember when you replace the IAC you need to drive it 20 to 30 miles so it can fully adjust. after first start it will run a little rough but after the drive it will be fine.
09-14-2015, 08:39 AM #5
That's a little too high for a vacuum leak.
I know it sounds crazy but have you been having any battery or alternator issues? If the ecm detects a low current it will go into limp mode to get the alternator to charge the battery. Can't hurt to test them.
09-14-2015, 01:14 PM #6
- Sep 2005
- Illinois
blue- 1970 Chevelle
Thank you for the ideas so far i appreciate it. Ive replaced all of the vacuum lines with new as well as the T's and Y's that connect them all together so that should take care of that issue. Ive also tried two other throttle bodies and also a new IAC on it and still am having the same issues. As far as i know the battery/alternator is functioning fine. The car always snaps right off when starting it and the gauges read that its charging. I can throw a meter on it just to make sure though and rule out that potential problem.
09-14-2015, 06:35 PM #7
Stock PCM or aftermarket engine controller? Do you have access to a scanner?
09-14-2015, 07:42 PM #8
- Sep 2005
- Illinois
blue- 1970 Chevelle
09-15-2015, 03:05 AM #9
HP Tuners has a great scanner function. I highly recommend that you sign up on the HP Tuners forum and watch some of the instructional videos and such. I bought HP Tuners Pro a few years back and it is kind of intimidating.
As noted above, high idle almost has to be excess air making its way into the intake. It has four possible ways to get there: 1) the throttle blade is opening too far; 2) the Idle Air Control Valve is stuck or not functioning properly; 3) a vacuum leak; or 4) a bunged up PCV system that is split open.
(BTW: When I answered above I was looking at your sig and saw "1970 Chevelle". I see that we are playing with a '98 Camaro now. My bad...)
09-15-2015, 03:13 AM #10
09-15-2015, 06:12 AM #11
Two other possibilities:
1) Idle set screw on the Throttle body.
2) The hole in the Throttle Body blade has been open up.
Those above are small in chance.Last edited by SMWS6TA; 09-15-2015 at 06:14 AM.
09-15-2015, 11:40 AM #12
when you changed the iac did you do a reset?
09-15-2015, 02:58 PM #13
- Sep 2005
- Illinois
blue- 1970 Chevelle
09-15-2015, 03:00 PM #14
- Sep 2005
- Illinois
blue- 1970 Chevelle
09-15-2015, 03:01 PM #15
- Sep 2005
- Illinois
blue- 1970 Chevelle
09-15-2015, 03:03 PM #16
- Sep 2005
- Illinois
blue- 1970 Chevelle
09-16-2015, 06:55 AM #17
I was just tossing out the less known possibilities. Have you checked the valve cover gaskets and the "port" on the top of the covers for the pcv?
09-16-2015, 07:01 AM #18
Is it possible the throttle cable itself is hanging up not allowing the throttle body to fully close?
What about a crack in the intake itself?Boost gets you laid, unless your name is Jon.
09-16-2015, 06:24 PM #19
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I was also thinking about a crack in the intake myself...especially on the back where the vacuum fittings are. When you reinstalled your intake did you follow the proper tourqe sequence? There is a certain sequence and increase in pounds. When I changed mine when moving in sequence some of the bolts would feel really loose after already torquing them. After several passes all was good. Just a thought..
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
idle issue.. may be tune issue.. help?
By okiels1 in forum General HelpReplies: 2Last Post: 12-07-2016, 02:17 PM -
idle issue
By jwest001 in forum General HelpReplies: 2Last Post: 11-05-2010, 08:33 PM -
New cam, idle issue
By allpontiac in forum Computer & TuningReplies: 8Last Post: 08-02-2010, 07:17 AM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 08:04 PM
