Results 1 to 3 of 3
Thread: idle issue
    Feb 2008
    torrid
    04 GTO
    idle issue
    im having a idle issue with my 04 gto when u first start the car sometimes it has a rough idle but after u let the car idle for a few mins it goes away ive changed the up stream 02 sensors my rear 02 sensor are tuned out and ive changed the plugs and wires still does the same thing im starting to think its the fuel here cause it never did it beofre i shipped it from ohio to hawaii the reason i think it might be the fuel is because they only sell 92 here and before i was putting 97 anyone ever have the same problem or any ideas what else to check?
    Veteran Blackbird WS6's Avatar
    van down by the river
    you clean your MAF?...throw a new fuel filter in it as well
    what are your mods??
    Member Eganslp's Avatar
    Oct 2009
    Philadelphia
    Sunset metallic orange
    '01 Camaro SS
    You could try what was happens to mine sometimes. I have the k&n setup and if I don't plug in this little sensor or If I forget to plug it back in after I clean it, it idles erratically plus I almost lost it a couple of times cuz it dangles just enought to hit the belts so I guess just make sure it's plugged in it falls out easily. You may not have know you lost it so just check to see that theres no detached wire
    Sent from my iPhone using Tapatalk
    The sound of your piss hitting the urinal.......yea it sounds feminine!
  1. idle issue.. may be tune issue.. help?
    By okiels1 in forum General Help
    Last Post: 12-07-2016, 02:17 PM
  2. Idle issue..
    By SilverBulletLS1 in forum General Help
    Last Post: 11-07-2013, 06:47 PM
  3. Help: Idle issue
    By SUPASLW in forum Internal Engine
    Last Post: 08-05-2012, 05:14 PM
  4. need help idle issue
    By usnfenix in forum General Help
    Last Post: 01-18-2012, 07:48 AM
  5. New cam, idle issue
    By allpontiac in forum Computer & Tuning
    Last Post: 08-02-2010, 07:17 AM
