Thread: Idle issue..
    Nov 2013
    Miami, FL
    2000 Trans AM
    Idle issue..
    So I have a 2000 Trans am I am having some idle issues just want to see what you guys think.. So when I start the car The idle goes up and down from 1000 -500 RPM for about 2 min after a little it will idle normal.. then if I put my A/C on the idle will drop to the point it wants to turn off that I have to accelerate to keep the car on.. again after a little it will go to normal again.. it will do this every time I start the car. Ideas?
    I have the following mods: the guy I got the car from told me he got it tuned but I am thinking maybe it was a bad tune..
    Fast 90mm manifold
    90mm TB
    Cam
    Pacesetter headers
    Off road Y
    Corsa 3' Exhaust
    Comp Valve springs and pushrods
    SLP Air Lid w/ K&N Filter
    180* Thermostat
    Stock Bottom End/Heads
    Quote Originally Posted by SilverBulletLS1 View Post
    Fast 90mm manifold
    90mm TB
    Cam
    Pacesetter headers
    Off road Y
    Corsa 3' Exhaust
    180* Thermostat
    BOLD is most likely the problem.
    Get some MAF cleaner from any parts store and clean it good, DO NOT TOUCH THE WIRE'S. You just spray it real good and let it sit and dry off. Since it most likely hasn't been done or has been a long time, I'd do it 2-3 times before installing it back on.
    K&N filters have a bad habit of messing with the MAF. It's the excess oil that owners forget to let air dry for a few hrs before re-installing it. The oil gets on the MAF and messes with it.
    Another area to look at is the IAC & TB sensors. The throttle body could be gunk up with excess blow by oil from the PCV. This will effect the idle.
    Check these items and then report back. Could be something as simple as a tune up.
    Nov 2013
    Miami, FL
    2000 Trans AM
    What can I use to clean the MAF? And what kind of oil should I put on the air filter as I read that as well?
    It's not what kind of oil to use with the K&N it's the amount of dry time. Most ppl don't follow the instructions and let it sit for 30mins - hr and throw it back in. IIRC it's suppose to sit for 3 or more hrs wrapped in newspaper.
    I use paper filters.
    Greensboro, NC
    2002 Trans Am WS6 M6
    My car had a kn filter on it when I got it. I always let it dry overnight after cleaning it and use MAF cleaner at least twice a yr. I had a slight idle issue until the first time I cleaned it.
    Nov 2013
    Miami, FL
    2000 Trans AM
    Thanks! doing this today when I get home, how is exactly do I oil the filter? do I damp a napkin and just rub it on? I was planning on doing it when I got home around 4 pm and re install the filter and everything at night around 8 pm to let everything dry.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Check the data stream and voltage from the IAC and if it is off, pull it, clean it with a quality cleaner and reinstall. Also make sure you do not have K&N oil on the MAF.
    Greensboro, NC
    There is a kit you can pick up from just about any auto parts store that kn makes. Just sprays on. Get a good even coating that is light. Go too heavy and it all just builds up on the MAF causing issues.
    Nov 2013
    Miami, FL
    2000 Trans AM
    THANK YOU!!!!! It worked!!! Idles like a dream now!!
    Another car saved from K&N
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Good to hear! I let mine sit for 30-45 mins after oiling mine. If you ever clean/oil yours, wrap the filter in newspaper or a paper bag so the paper soaks up any excess oil.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    I actually let my filter sit overnight just to be on the safe side.
  1. idle issue.. may be tune issue.. help?
    By okiels1 in forum General Help
    Last Post: 12-07-2016, 02:17 PM
  2. Help: Idle issue
    By SUPASLW in forum Internal Engine
    Last Post: 08-05-2012, 05:14 PM
  3. need help idle issue
    By usnfenix in forum General Help
    Last Post: 01-18-2012, 07:48 AM
  4. idle issue
    By jwest001 in forum General Help
    Last Post: 11-05-2010, 08:33 PM
  5. New cam, idle issue
    By allpontiac in forum Computer & Tuning
    Last Post: 08-02-2010, 07:17 AM
