    Junior Member trnsman's Avatar
    Apr 2012
    East Hampton Connecticut
    pewter
    2002 Pontiac transam
    los of acceleration on a hard pull.
    On a hard acceleration from 70 mph Tac gets above 5 grand and drop down to about 3 grand during which there is no acceleration, why?
    Possibly your knock sensors are kicking in and the PCM is pulling timing... although that would have to be extreme. Other possibility is a fueling issue and it is running out of gas, which causes a lean condition... which is very bad.
    Junior Member RCH33's Avatar
    Jun 2015
    Greenwood, IN
    Yellow
    2002 Trans Am CE
    Just had a tune where the knock blocker would retard the timing 8 degs and then start bringing it in again. You can definitely see it on the Dyno chart. As Jeff says, fuel would do the same thing. Check the fuel,pressure readIng and see if it drops or not. See what your timing is at that load and rpm. You can retard timing a little and enrich the air/fuel at that point to keep it away from the knock block. A tuner can make the PCM add timing back a little faster than stock also. My tuner likes to keep everything right below the knock block to keep a good steady pull. I only lost 1hp and 1 ft/lbs of torque with a tune that keeps it out of knock block and feels much better. Probably better on the engine too.
    But, again as Jeff says: 5 grand to 3 is a big drop and seems like there might be something else. How fast does this take place and when do you start feeling the rpm's rise again.
    any back fires? smoke in the exhaust?
    need more info on this....like specifics about what exactly the car does.
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    I will bet you a thousand dollars it's a fuel pump
    98' Trans AM RIP
    00' WS6/Black/Pacesetter LT's/Magnaflow Exhaust/SLP lid/Nick Williams 92mm TB/FAST 92 Intake/BMR Strut Tower Brace/BMR Rear LCA's/BMR Panhard Bar
  1. Acceleration
    By BDowning in forum Almost Anything Goes
    Last Post: 07-13-2009, 06:10 AM
  2. Help: Burning oil under hard acceleration/deceleration
    By Blakeman in forum General Help
    Last Post: 06-28-2009, 02:45 PM
  3. Noise under hard acceleration-auto tranny related
    By Zapper2003 in forum General Help
    Last Post: 03-14-2008, 05:31 PM
  4. acceleration at WOT
    By totalkos in forum General Help
    Last Post: 11-25-2007, 12:01 PM
  5. cracking noise on hard acceleration
    By zetwentyeight in forum Automatic Transmission
    Last Post: 12-18-2006, 01:18 PM
