    May 2015
    ny
    2002 TA WS6
    clutch slipping all gears
    Hello everyone, I'm new to this site and would like to thank everyone up front for the help.
    2002 WS6 with an handful of mods, mostly the trick flow top end kit that gives me 425 RWHP. Anyway the car has been in storage on jack stands for 6 years. (2 years into storage I drove it for 3 days and no problems and put it back into storage for the additional 4 years). Anyway so its now out of storage and I drive it for the first time and the clutch is slipping all over the place!! Every gear! If I baby it, it might not slip. I'm assuming its a layer of corrosion on the flywheel cause most everything else has a layer on it. Is there anything I can do that doesnt involve pulling the flywheel? Someone told me if I baby it for a while it should wear the layer off and be fine.
    Any suggestions?
    It's possible the clutch material has attached it's self to the flywheel. But that should rub off after a few shifts.
    You should drain all fluids and replace. Sitting that long all oils and coolant do go bad as well as gas. Seals will dry rot and crack. Surprised you are not reporting it's not running right.
    It's possible the slave & master have gummed up. That's where bleeding the systems will help identify. And I also mean drain and refill the transmission.
    For the clutch use DOT III or IV Brake fluid and for the transmission itself ATF. If you reverse that you'll be getting a completed rebuild on both components.
    ^^ Agree. Sitting for extended periods is harder on our cars (or any car for that matter) than driving them.
    Junior Member wraith23's Avatar
    May 2015
    Maryland
    2000 Trans Am
    Completely agree here. This is where you need you to start.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    ^^^ What they said ^^^
  1. Help: 3-4 clutch is slipping again.....
    By z28punk in forum Automatic Transmission
    Last Post: 06-06-2009, 02:44 PM
  2. Is my clutch slipping??
    By GottaHaveLS1 in forum General Help
    Last Post: 12-17-2008, 08:17 AM
  3. new clutch slipping
    By JER-SS in forum Manual Transmission
    Last Post: 07-21-2008, 06:09 AM
  4. Slipping clutch
    By Mr. Luos in forum Manual Transmission
    Last Post: 03-17-2007, 03:34 PM
