Results 1 to 17 of 17
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    Your own car lift.
    I've gotten a few e-mails about the car lift in my garage heres the deal. I would recomend calling new lift dealers, back in the day garages had lifts rated for up to 7K lbs which is normally half the weight they can handle so to be on the safe side. Dealerships however are upgrading lifts constantly to go to heavier load lifts. It takes a lot of phone calls normally - check ebay as well but shipping can KILL YOU. I bought this one for 800 cash - cash will help lower the cost when negotiating prices. I had to invest 35 for a new hydraulic hose - one had a tear, about another 40 in concrete anchors, and nearly 80 in sandpaper / spray paint. I had them load it onto a trailor and had 5 guys help move it into my garage whaere withing a week and a half I worked on "Appearance" of the lift. I also had a neighbor with a industrial hammer drill help measure remeasure then drill the holes, and hook up the electric which ran me about another 50-60 bucks (neighbor again - jack of all trades) - I had to "redo" my electric box to bring in the 220 service but hooked a garage heater to that. The heater has to be off when operating the lift - so I don't throw the fuse. The hydraulics do go into the upper part of my attic in my garage I cut holes in the attic and covered the holes with an 80 cent black mud flap from wally world to make it look better. the mud flap simply lifts along the side when the lift is up high I also have a garage door opener which I cut two small holes and disconect the opener from the garage door then push the door opener up into the attic area and bolt it down - takes 5 minutes but I only do this when I've got a big job to do. If you want send me a pm - I'll send you pics of my setup just give me time to take photos you want. Also I invite any of you to come by and use the garage if I have time - and if the job can be done in a day - just contact me and we can work out when and what needs to be done. Even though I have 10' ceiling it still gets the car over 5 feet. I also purchased stabilizer jacks so the car doesn't rock if working something out - freight harbor tools. It was a lot of work to get this thing from the early 80's somewhat rusty heavy metal to holy crap you got a lift in your garage! Also make sure any lift you buy has safety locks that work!!! I recheck the torque on the bolts monthly - AND MOST IMPORTANT MAKE SURE YOUR FLOOR IS THICK ENOUGH! I have 41/2 " of concrete which gets it done for my 2 small cars but I am scared to put the Durango on there... They recomend at least 5" but my neighbor said it's strong enough for what I need. If it isn't thick enough you can have new footers cut out and tied in then poured - but your talking money then... I have done a lot of research on this so if you have any questions regarding types of lifts etc drop me a line maybe I can get you a helpful website or send you to Bucky who is the mechanic who installs lifts where I bought mine - great guy but you'll have to go through the company to talk to him. I justified this with my chief financial officer when the dealer wanted close to 2600 to do all the hydraulics on my clutch and the clutch itself - plus took care of a leaking rear seal while I was under there which would have added another 200 or so dollars - so I saved money and came out with a lift - might work if you have a similar situation... Jacking the car up use to take me upwards of 30 minutes now it's literally 2 minutes put the stand under raise it check it's stable and continue going up watching close so I don't run it into the roof garage door opener etc. Another important factor Bucky told me always undo my t-tops before lifting the car he said this can crack them!!! I'm not going to test to see if this is true or not - I just do it to be safe... Take care and hopefully this was somewhat helpful. Attachment 4208
    Member myk02k's Avatar
    Mars
    2002 Camaro Z28 6-spd
    i love thos things
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    I would love to have a lift in my garage when I build it.........I would like to be able to stand under the car fully so I guess I should build it with atleast twelve foot ceiling?.... Sweet even if just doing an oil change.........gotta love any exhaust work or rotating tires with that
    Fredericksburg Va
    01 Trans Am
    The best thing would be to call your local lift dealer discuss options new vs used and if they have any used then discuss concrete thickness / ceiling height and overall garage plans with them! This would be CRITICAL as far as which type of lift you decide to go with most lifts nowadays have the hydraulic hoses / cables running across a top bar the one I wanted needed at least 12' 8". Mine are under the yellow ramp at the bottom of the floor - but this poses some interference with transmission jacks etc - but I always work around it. If I did it for a living it would be a pain but suits my needs just fine. If you work with a lift dealer I have always found that they will be MORE THAN HAPPY to accomodate you in any way they can! Let me know how it works out and I'd love to see pics when done!
    central wisconsin
    It won't be for a couple of years yet...........but I can't wait
    Midwest Member Topless TA's Avatar
    Kansas City Suburbs
    WS6 M6 Vert
    very sweet
    Member Wyoming T/A's Avatar
    Powell,WY.
    1999 Trans AM 30th anniv.
    if you are looking for a lift ,best price is at Garage Equipment 9000# twin post is under $2600 ,usually free freight,we have 2 in our shop both Bend Pak,great lifts
    aggiez28
    Guest
    i wish i had room for a lift
    Mars
    for those of you who can't afford it but have a house, why don't you just make a ditch on the side of your house and pour concrete so it looks 1/2 way decent? itll save you $2000
    Mars
    for those of you who can't afford it but have a house, why don't you just make a pit on the side of your house and pour concrete so it looks 1/2 way decent? itll save you $2000
    Mar 2003
    Melbourne, FL
    My gramps just put his out in the open.
    DFW
    '18 CTS-V
    '13 ZL1
    [QUOTE=Sassy Cassie]My gramps just put his out in the open. [QUOTE]
    holy crap sassy thats bad ass. nice car too!
    2013 ZL1: °°590rwhp/576rwtq°°
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Nice lift
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Black/Screaming Yellow
    99 S/C TA WS6 & 04 Cobra
    Quote Originally Posted by Sassy Cassie
    That is my car!
    1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
    10.29@129 w/1.60 sixty foot
    2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
    Minnesota
    '10 ZR1
    Quote Originally Posted by Packy
    That is my car!
    Ohhh, I thought it was Cassie's car!
    ;) Packy's Avatar
    Apr 2001
    Surf City, NC
    Quote Originally Posted by FasstChevys
    It is ours!
    Minnesota
    '10 ZR1
    It is ours!
    It's cool, I was just joking/teasing
  1. Max Jax Lift
    By MrKid in forum Tools
    Last Post: 11-06-2016, 04:34 AM
  2. I have a .630 lift...?
    By MurderedOutTA in forum Internal Engine
    Last Post: 10-20-2010, 03:56 PM
  3. how much lift is ok?
    By TmaxicanA in forum Internal Engine
    Last Post: 03-06-2008, 11:06 AM
  4. Looking for a Used LS1 Cam 590 or less lift
    By Regal Performance in forum Firebird / WS6
    Last Post: 11-01-2006, 06:44 AM
  5. Best cam for .600 max lift?
    By phoenix1987 in forum Internal Engine
    Last Post: 10-01-2006, 09:41 AM
