04-25-2006, 09:53 AM #1registered cobra eater
- Apr 2006
- Dayton, OH
black- 2000 Trans Am
just installed FIPK, car wont start sometimes
i have a basically stock 00 TA and i just installed an FIPK and about an hour after i drove it the first time i go to start it up and it wont even turn over. i tried about five times and still nothing, the guages all read ok (including the battery) i let it sit for a few and it started right up. This has happend to me about 4 times now. I have no clue what is goin on with this, any help will be great!.
04-25-2006, 10:17 AM #2
Could be a pass II prob....do a search and you'll find some info on it. Also make sure you plugged the maf and iat back in.
04-26-2006, 11:26 AM #3registered cobra eater
- Apr 2006
- Dayton, OH
I checked on the MAF and all the other sensors and all is well, what do u mean by pass II?
04-26-2006, 11:53 AM #4Junior Member
- South Jersey
artic white- 2000 ss
Did you disconnect the neg bat. terminal before install?If not do pcm reset.
04-27-2006, 09:26 AM #5registered cobra eater
- Apr 2006
- Dayton, OH
i think i found the problem, it was the tip of the negative battery cable was worn down so it wasn't getting a good connection. thanks for the help
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
installed gauges now car wont start.
By matt evans in forum General HelpReplies: 3Last Post: 05-17-2012, 10:46 AM -
Help: wont start!!!!!!!!!!!!!!!!!!!!!!
By victor111262 in forum General HelpReplies: 26Last Post: 09-30-2010, 10:18 PM -
95 3.4L Wont Start
By Fast95Bird in forum V6Replies: 4Last Post: 01-22-2007, 11:09 AM -
Installed New Walbro pump...car ran fine for 5 minutes then quit..wont start
By Hamster Dance in forum General HelpReplies: 26Last Post: 01-17-2006, 09:51 PM
