05-15-2012, 08:25 AM #1
installed gauges now car wont start.
ok i have been awake now for going on 36 hours. Came home from graveyyard and procedeed to finish hooking up my gauges and redoing my nitrous wires. Got it all done and the car wont hit for nothing. Im getting fuel and pulled a coil wire and seen fire so i dont know what the issue is right now. I know im tired as hell and its probably something stupid but if i can get any help right now that would be awesome thanks. its on a 02 camaro. like i said i need sleep but this is bugging me.
05-15-2012, 05:45 PM #2
Check your fuses for the gauges. Mine did the same and spend hours tracking wires to find out it was a bad fuse. Don't just look at it, replace it! The gauges fuse also kills the starter. If its not even turning over start there.
05-15-2012, 07:05 PM #3
found the problem after i said screw it and went to sleep. My fuel solenoid from my nitrouos was open and after pulling the shrader valve it was dumping fuel down the cylinders. Pulled the plugs(needed to anyway to put the ngk's in) basically after pulling the pump fuse and turning the motor over and blowing out a half gal of fuel out the exhaust, it fired up and running fine. Just one of those things that happens when staying up too damn long.
05-17-2012, 10:46 AM #4
Completely understand.
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Car Wont Start, When Jumoped Gauges turn off + On?
By Patsy57 in forum Stereo and ElectronicsReplies: 3Last Post: 04-11-2008, 11:26 AM -
95 3.4L Wont Start
By Fast95Bird in forum V6Replies: 4Last Post: 01-22-2007, 11:09 AM -
just installed FIPK, car wont start sometimes
By KillerTA00 in forum General HelpReplies: 4Last Post: 04-27-2006, 09:26 AM -
Installed New Walbro pump...car ran fine for 5 minutes then quit..wont start
By Hamster Dance in forum General HelpReplies: 26Last Post: 01-17-2006, 09:51 PM
