Thread: generator L terminal circuit
04-21-2015, 09:07 AM #1
Throwing a generator L terminal circuit code...not sure what it is could use some help
98' Trans AM
RIP
00' WS6/Black/Pacesetter LT's/Magnaflow Exhaust/SLP lid/Nick Williams 92mm TB/FAST 92 Intake/BMR Strut Tower Brace/BMR Rear LCA's/BMR Panhard Bar
04-21-2015, 10:06 AM #2Spaz is My Mentor
have you messed with the alternator or wire harness lately?
Gen L terminal for GM is the circuit that turns on and off the alternator when need be. It sends a source voltage signal from the pcm to the back of the alternator to the stator windings to fire up the alternator...thus a check in that circuit would be your first start..go down to the alternator and there's only one small wire in a connector on the back...and trace that wire...or u can power down and isolate the circuit and disconnect the pcm connector and check resistance from the wire at the alt to the wire at the pcm
04-22-2015, 10:33 AM #3
Haven't messed with the wiring harness at all or the alternator. Got it dyno tuned yesterday and that was one of the codes. I told the guy not to delete it and I'll trace the issue. I'll have to look tomorrow afternoon to see if the alternator is functioning proper or if I can find any loose wires
04-23-2015, 11:00 AM #4
Checked ground wires and they all seem ok. Maybe this is a sign the alternator is on its way out?
generator people......
By 0rion in forum Almost Anything GoesReplies: 0Last Post: 10-25-2011, 08:55 AM -
where exactly is the positive terminal for Alt.
By qwik219d9 in forum General HelpReplies: 5Last Post: 10-30-2009, 11:47 AM -
Alternator/generator problems
By Stoneflye in forum General HelpReplies: 0Last Post: 08-22-2007, 02:29 AM -
I can't disconnect the battery terminal!?!?!?!
By johntm86 in forum Firebird / WS6Replies: 2Last Post: 05-06-2006, 08:28 PM -
Generator L-terminal circuit?
By ryan_gilson in forum General HelpReplies: 0Last Post: 04-10-2006, 03:19 PM
