Thread: whirring noise
04-04-2015, 05:49 PM #1
whirring noise
Transmission shifts just fine, just the annoying sound when car is in gear. Im hoping it just needs a flush even though the fluid is still the right color and unburned. Please help.
2005 Impulse Blue GTO
Kooks Longtube Headers (off-road mids) , SLP Loudmouth II Catback, Vararam OTRCAI, MSD Spark Wires, 238/242 .595, Trickflow 225cc Heads, SLP 25% UD Pulley, Breather, Elite Engineering Catch Can, 3200 TC,Hayden Trans Cooler, P&P TB, Dyno tune by Sunshine Performance
04-04-2015, 08:09 PM #2
can you isolate the noise?
Maybe the rear?
Were you doing any fun stuff?
04-05-2015, 05:18 AM #3
Sound coming from transmission. Been making this noise for a little, but is a little worse after the track friday. Stock convertor going out? Are transmissions ever a little noisy for no reason?
04-05-2015, 09:24 AM #4
Idling does it make the sound, or only in gear?
04-05-2015, 03:53 PM #5
Only in gear
04-05-2015, 04:24 PM #6
Its not very loud either... plus car drives great. No hard shifting, loss of power, or noise other than the whir. Has always made this sound. Really hoping its normal, especially because the fluid is fine.
04-06-2015, 04:10 PM #7
Took it to aamco, and its my torque convertor or pump. Ill know more tomorrow.
04-06-2015, 04:28 PM #8
- Jun 2011
- Branchville, NJ
The front pump is usually the issue when hearing this noise especially under load. Go to a private trans shop with a good reputation because the "Chain Transmission Shops" almost always want to rebuild the unit. If the trans is good and shifting fine you should just do the front pump for now.
04-07-2015, 03:15 AM #9
Give Performabuilt a call... they'll fix your "whirring" issue and install a permanent grin on your face every time you smash the loud pedal.
04-07-2015, 12:13 PM #10
Theyll know more after they open the thing up. If they tell me its just the pump im gonna have them replace that and upgrade the stall. This is an individually owned aamco, and my wife goes to church with the owner. Lol if that means anything.
04-07-2015, 04:33 PM #11
04-10-2015, 03:13 AM #12
Make sure you get the Beast sunshell and the upgraded version of the pump (more vanes). If you have a tune that ups your line pressure and install a modified valve body that does the same, you will want to adjust your tune back to around the stock pressure settings or it'll shift like crap.
help with noise
By jodmari in forum General HelpReplies: 8Last Post: 06-12-2014, 08:48 AM -
Help: The Bird is making a whirring noise after ignition cut?
By BdAsBrd01 in forum General HelpReplies: 2Last Post: 12-25-2011, 07:49 AM -
whirring noise, should I be worried?
By LeadFarmer in forum DrivetrainReplies: 0Last Post: 10-25-2010, 06:23 PM -
T-TOP noise
By Dr.Crash in forum General HelpReplies: 22Last Post: 02-17-2009, 08:20 AM -
Help: noise
By rude_red in forum General HelpReplies: 2Last Post: 07-02-2008, 03:00 AM
