Results 1 to 15 of 15
02-14-2015, 10:07 AM #1
- Feb 2015
- EL RENO OKLAHOMA
BLACK- 1998 TRANS AM
Replaced fuel pump and now gage is inop
I have a 98 ws6 that i replaced the fuel pump on with a new gm pump. After installing it my gage quit working. I took it back out and manually moved the float and still nothing. I got another new pumpasm and hooked it up and same thing. Anyone ever heard of this or can give me any ideas? Thanks tom
02-14-2015, 10:11 AM #2
did you reconnect the wire harness? there are 2 IIRC.
02-15-2015, 09:36 AM #3
- Feb 2015
- EL RENO OKLAHOMA
Think i have it narrowed down to 2 bad modules. Hooked up the old pump and gage work perfect. Gonna get a new one on tuesday and try it again. Thanks
02-15-2015, 10:51 AM #4
That sucks when you get "new" stuff it doesn't work....
02-18-2015, 02:58 AM #5
Agreed. Very frustrating. Let us know if this fixes it.
02-18-2015, 09:22 PM #6
Please be sure to keep us updated on this issue....my 98 Forged 347's fuel Guage has stopped working for a while now and won't change regardless of what module I install. .thanks
02-21-2015, 11:10 AM #7
- Jan 2009
- North Jersey
"New" stuff and it either doesn't work, or you need another part to GO with the "new" stuff. Know the feeling.
02-21-2015, 02:38 PM #8
02-21-2015, 02:41 PM #9
02-22-2015, 05:40 AM #10
I would pop the connector back by the tank, locate the sender wires, and then check the ohm reading to see if you have a legitimate reading or if the circuit is open.
02-22-2015, 09:56 PM #11
02-23-2015, 03:49 AM #12
I have a 98 TA and replaced my pump with a Racetronics 255lph. Didnt have any issues at all. I did the "trap door" mod though. Just incase I need to access it again it will only be a 20 min job!!
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
02-23-2015, 05:16 AM #13
Although I swore I would never cut a hole in our car, when it came time to replace the fuel pump I also went with the trap door. I'm glad I did as I then had some issues with the fuel pressure regulator after the fact and ended up pulling the pump 4-5 more times to get it all straightened out.
02-23-2015, 01:31 PM #14
What happens there are little fingers on the sender and the 98 have a metal tank with baffels inside you have to install the pump just at the right angle or the float hits the side and damages the sender.
02-24-2015, 05:40 PM #15
Ls1 won't start/ just replaced fuel pump
By Bigjames25 in forum General HelpReplies: 7Last Post: 10-09-2013, 09:02 PM -
Replaced Oil Pump. Low pressure, no noise.
By Black LS1 T/A in forum Internal EngineReplies: 22Last Post: 12-14-2011, 06:36 AM -
replaced fuel pump today
By redbird98 in forum Camaro / SSReplies: 6Last Post: 10-28-2010, 09:56 PM -
Help: Replaced Fuel Pump, Gas POURING out of cap! Help**
By SteelCityTA in forum General HelpReplies: 4Last Post: 04-24-2009, 11:27 AM -
got fuel pump replaced, now gas mileage is crap
By chris5 in forum General HelpReplies: 4Last Post: 06-25-2007, 08:40 AM
