Thread: replaced fuel pump today
10-23-2010, 04:40 PM #1Junior Member
- Aug 2006
- missouri
red- 98 trans am
I replaced the fuel pump in my sons 96 T/A today. I dropped the tank instead of cutting the floor open and I'm glad I did. I just couldn't bring myself to cut a hole in the floor of the car. It took me about 4 hours on my my garage floor, this was my first time doing it. I really didn't think it was that difficult to do, just a lot of stuff to unbolt. It would definately be easier the second time if ever needed. I chose to replace the complete fuel pump/sending unit assembly with the correct GM part, a simple part swap, no wiring to change or disassembly of the pump assembly. I searched many threads on this sight before I did this job, and there were helpful hints in many of them, so thanks for the help.
10-25-2010, 02:13 AM #2Junior Member
- Oct 2010
- Maryland
black- 2000 Z28
Fuel pump replacement.
Hey Redbird, glad to hear that dropping the tank was not too hard. I saw the postings for cutting a hole in the floor and it made me think that dropping the tank must be impossible. I'm thinking that my pump may be bad because my 2000 Z28 performance fluctuates, as if it is not getting fuel. The shop checked fuel pressure at idle and found 60 PSI, and I have changed the fuel filter and spark plugs. What kind of symptoms did you have with your bad fuel pump?
10-25-2010, 03:57 AM #3
Did mine in about the same amount of time.. Pretty strait forward really..
Usually (not always tho) a higher than normal whinning sound will be heard or intermittently.. Car will stop running @ anytime and need flat bedded to your shop or another..
10-25-2010, 01:10 PM #4Junior Member
- Aug 2006
- missouri
red- 98 trans am
actually, I just bought the car and the place I bought it from told me they had replaced the fuel pump. The car would not start on initial crank, had to crank, then stop, then crank again. Then I also discovered the fuel gauge was not registering correctly. So I figured they damaged the sending unit when they installed the cheap fuel pump, and then didn't get the clamp tight on the little hose that comes off the pump. I checked it with a fuel pressure gauge, and after turning the key off, pressure would drop to zero almost immediately. Also after hard accelleration and then getting off the throttle and then back on it, it would sputter and cough. Now after replacing the pump assembly, it fires off instantly, runs fantastic, and the gauge works.
10-25-2010, 01:15 PM #5
10-28-2010, 05:57 PM #6
did mine in my '98 TA a couple of months ago and dropped the tank. llike you, i don't like cutting holes in things if i don't need to. it's just a lot of work unbolting everything, with the exhaust really being the biggest PITA depending on its age and how it was installed on the car. my only hangup was the filler tube on the reinstall, but got past it by cussing up a storm...lol
10-28-2010, 09:56 PM #7TJEA Retirement Home
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
I just cut the hole in my trunk. I know most people will say it's due to laziness, but i just didnt want to get it all back together and find out it didnt work. Plus most people will never know its there (and yes of course if i was going to sell it i would tell the buyer). However, more power to all of you who have spent the time to keep your baby a virgin.
Replaced fuel pump and now gage is inop
By TRANSWORLD43 in forum General HelpReplies: 14Last Post: 02-24-2015, 05:40 PM -
Ls1 won't start/ just replaced fuel pump
By Bigjames25 in forum General HelpReplies: 7Last Post: 10-09-2013, 09:02 PM -
Replaced Oil Pump. Low pressure, no noise.
By Black LS1 T/A in forum Internal EngineReplies: 22Last Post: 12-14-2011, 06:36 AM -
Help: Replaced Fuel Pump, Gas POURING out of cap! Help**
By SteelCityTA in forum General HelpReplies: 4Last Post: 04-24-2009, 11:27 AM -
got fuel pump replaced, now gas mileage is crap
By chris5 in forum General HelpReplies: 4Last Post: 06-25-2007, 08:40 AM
