Results 1 to 14 of 14
Thread: revs(idles)high after highway
04-23-2006, 09:46 AM #1
i have a 01 ss m6..when i take out on the highway and im goin around 90mph(fast) and i come back into town when i drop it in nuetral the cars revs stay at like 3000rpms???when its in nuetral and they slowly come down as the car slows down.. even though its in no gear????is it a bad clutch i cant figure it out
04-23-2006, 12:04 PM #2
Sounds like a clutch problem, maybe your clutch is not releasing fully,or is adjusted too tight ,or slipping and heating up, or ........?
04-23-2006, 04:02 PM #3
thats what i was thinkin.. so most likely its a clutch issue
04-23-2006, 05:09 PM #4
Yes, do you have trouble getting it into gear also? Shifting it when it stays revved up? Of course this would be bad for the transmission. Need to check if the clutch master cylinder is leaking or low on fluid.
04-28-2006, 10:30 PM #5
well it cant be a clutch issue because when i turn off the car while its doing it and restart it even if i start her up rite away she runs fine...i do have a cutout and it started to do it after i got it..but im not sure if its that?
05-01-2006, 03:18 PM #6
05-01-2006, 06:54 PM #7
Perhaps a vacuum leak?? That would cause it to idle high like that, check to see if any hoses came off in the engine bay.
05-01-2006, 09:28 PM #8
hmm no all the lines seem to be in place...could it be the alternator or maybe something connected to the belt? but this only happens after highway driving..im lost
05-02-2006, 09:38 AM #9BeastGuest
I drive 45 miles on I-20 twice a day with the cruise set to 80mph and about every other day my car does the same thing once I get back into town. I'll jump off the highway and sit at red lights idling at ~2500 rpm. It's been doing it for about a year.
I replaced the master/slave cylinder, clutch/pressure plate... so that's not it.
Let me know if you figure it out!
05-02-2006, 12:34 PM #10Something with the cruise control perhaps??
Originally Posted by Beast
Does it only do it when you use the cruise??
05-02-2006, 02:01 PM #11
no i dont even use the cruise..so i dont know what it could be..the car goes through gears just fine..i got off the highway today and it was normal but then i downshifted cus some guy in a van was floorin his so i thought he wanted me to so i did...and well the problem came backk.maybe the clutch isnt disengaging <-- srry
05-03-2006, 07:38 AM #12BeastGuestI don't know... I'll try driving without the cruise today and see if that changes anything. I hadn't thought of that relationship.
Originally Posted by Wesman
**JattGunMan, I'm not trying to hi-jack the thread or anything. I just thought I would throw my car into this since I have the same problem.
05-03-2006, 09:34 AM #13
Might want to check if your throttle is sticking. Sometimes if the TB gets all dirty it can stick.
05-03-2006, 10:00 AM #14
Idle air control valve. Clean it or replace it.
98 t/a idles high
By heath26 in forum General HelpReplies: 4Last Post: 05-16-2010, 11:48 AM -
revs seem funny?
By mammoth713 in forum General HelpReplies: 10Last Post: 10-23-2009, 07:29 PM -
Engine revs high at start
By !!!FAST!!! in forum General HelpReplies: 7Last Post: 08-31-2009, 07:44 AM -
!! help lt1 idles too high @ 1500 rpm !!
By onemedina in forum General HelpReplies: 2Last Post: 08-07-2006, 09:25 PM -
Revs
By johuckabee in forum External EngineReplies: 0Last Post: 02-23-2006, 06:17 AM
