Thread: Engine revs high at start
08-30-2009, 08:57 AM #1
Just added a BBK SSI intake, SLP cai, SLP lid, and SLP smooth bellows. Went and started the car and now it automatically revs to about 4,000 rpms then dies. If I try to keep it running by feathering the accelerator it will rev back up to about 3,000 rpms and starts to pop (backfire). Also I noticed my oil pressure guage is pegged above 80 psi but thats even with the engine stopped and ignition on. I was really careful when removing the old intake and installing the new one not to bang anything up against it. But it is a tight fit getting behind there. Any suggestions on the revving would be greatly appreciated.
Boz
08-30-2009, 09:09 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Sounds a air leak and your OPSU is broken off or not plugged in.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
08-30-2009, 09:11 AM #3Electrical Engineer
- Jul 2009
- North of the Motorcity
Sounds like a an air leak to me too.
08-30-2009, 09:14 AM #4
I agree with these two. Also, breaking the OPSU seems to be common for intake manifold installation as many people have done it.
08-30-2009, 09:35 AM #5
Where would be the most likely place for the leak? I've checked all the air connections and they all seem to be fine.
08-30-2009, 01:51 PM #6
08-31-2009, 07:35 AM #7Senior Member
- Apr 2008
- Madison, WI
read this and see if it helps you.
http://www.ls1.com/forums/showthread.php?t=120082
08-31-2009, 07:44 AM #8King 0f n00bz
- Jan 2006
- Shepherd, Michigan
i say a leak...1. when installing the manifold..a lot of people kind of slide it in..and the gaskets catch on the edges of the intake ports of your heads..so they pop off and create a leak..also..over torquing a nylon composite intake (ls6,ls1,fast etc ) ..will cause a crack..(ask me how i know) ...and lastly..not breaking off the clips that hold the knock sensor wires will also cause issues as will old style coolant pipes with a ls6 or similar.
warm/hot start HIGH rev idle/ sticking throttle??3800
By rschap1 in forum V6Replies: 18Last Post: 04-03-2012, 03:56 AM -
Help: Engine Revs/Car Moves On It's Own
By abarthle in forum LT1Replies: 3Last Post: 04-08-2010, 01:28 PM -
Oil pressure high...75 at start & until warms up
By Z28er in forum General HelpReplies: 13Last Post: 04-07-2010, 12:53 PM -
High reving on cold start up
By WS6LS198 in forum General HelpReplies: 6Last Post: 02-24-2007, 10:27 AM -
revs(idles)high after highway
By JattGunMan in forum General HelpReplies: 13Last Post: 05-03-2006, 10:00 AM
