    Sep 2014
    Cary, NC
    Spark plug change goes wrong!
    So I was changing the spark plug for cylinder 1 and I unplugged the plug that is right next to it to make it easier. Somehow it just completely ripped off! Can I just like super glue it back on or something? Help please! I attach a pic to make it easier to know what I'm saying lol.
    Thanks for the input
    Attached Images Attached Images
    Sep 2014
    Cary, NC
    Another pic
    Sep 2014
    Cary, NC
    Looking thru the list of sensors thread it looks like the Engine Coolant Temperature (ECT) sensor. Any ideas how to repair it?
    Just replace it. The PCM needs to know engine temp to control open and closed loop fueling, among other things. I wouldn't risk it and recommend you pick up a new one from the dealership in lieu of a parts store cheapie. If you are quick about it, you should be able to swap out the sensor with minimal coolant loss. You'll create an air pocket, so watch your temp the next time you start the engine to ensure that you do not airlock the thermostat. Other than that, it's a simple fix.
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    X2 what pajeff02 said. It's a cheap fix and not worth trying to 1/2 a$$ it. I did the same thing when I did my 1st plug change. I broke the end off of the sensor. I tried to "ridge" it, but it keep falling off. I just bought a new sensor and some antifreeze. Replaced the sensor and didn't even loose enough antifreeze to make a difference in the water level.
    Sep 2014
    Cary, NC
    How do I replace it? Just unscrew the brass part and put a new one in?
    Get the $35 replacement and either use thread sealant or teflon tape around the threads. Use a 3/4" socket or wrench and back it off. Have a drip pan because it's going to drain the coolant. Replace and tighten down.
    I had the same situation like you, my sensor worked for a while but in time it started giving bad readings. Once I swapped it out everything fine again.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    Super Glue......really!!!!
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
  1. WS6 Spark Plug Change
    By kheflw in forum Firebird / WS6
    Last Post: 02-21-2012, 12:52 PM
  2. spark plug change
    By Pony_Eater in forum General Help
    Last Post: 09-20-2011, 06:55 AM
  3. Spark Plug change
    By Vince from Shamwow in forum General Help
    Last Post: 06-11-2011, 12:10 PM
  4. spark plug change problem
    By ls1wallen in forum External Engine
    Last Post: 02-25-2010, 01:05 PM
  5. Question: Spark plug change on a V6
    By M-ManLA in forum General Help
    Last Post: 03-31-2009, 11:29 PM
