Thread: Key Ignition Wire +12 volt
10-30-2014, 01:26 PM #1Junior Member
- May 2010
- Queens, NY
Black- 2000 Trans Am
Hi all,
I just bought 2 autometer gauges, Fuel Pressure Gauge and a Boost/Vacuum gauge for the center A/C vents. Gonna buy a third gauge soon. For my 2000 Trans Am LS1.
They are digital not mechanical.
Here is the the Boost/Vacuum gauge I bought #5959:
Auto Meter - Gauges
My question is, the Installation guide writes that the Red + wire should be connected to a +12 volt source that maintains power during engine cranking.
I was gonna connect to the radio until I read about this. The radio turn off when cranking.
Where can I connect that doesn't turn off while cranking? Or is there a direct wire coming from the key ignition that I can connect to?
Here is a picture of the wires from the steering column.
Thank you!!Last edited by 1batt4u; 10-30-2014 at 01:30 PM.
10-30-2014, 01:36 PM #2Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
I know our cars have an AUX post under the hood that supplies juice, but not sure if it supplies power when cranking...might be something to look into if you can't get one under the dash somewhere.
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
11-01-2014, 10:27 AM #3Junior Member
- May 2010
- Queens, NY
I was googling it and someone mentioned a pink wire to tap into that has +12 volts while cranking. I'm not sure which pink wire from my picture. 1st one on left or middle?
Anyone knows?
11-17-2014, 02:47 PM #4Senior Member
- Feb 2006
- Orange County, NY
If you have a test light you can check.
MSD super conductor ignition wire.
By weberje in forum General HelpReplies: 6Last Post: 09-05-2010, 06:50 PM -
Taylor ignition wire crimp tool...
By LT4Hawk9 in forum LT1Replies: 5Last Post: 06-02-2010, 02:52 PM -
Help: Volt Problem
By 99blueLS1 in forum General HelpReplies: 1Last Post: 06-07-2008, 04:50 AM -
Volt gauge
By GNICTRY in forum General HelpReplies: 4Last Post: 10-08-2007, 04:45 AM -
16 Volt ?'s
By wildkatz in forum Stereo and ElectronicsReplies: 1Last Post: 06-26-2006, 09:59 PM
