05-27-2010, 07:51 AM #1Member
- Apr 2006
- Bridgewater, VA
Black- 1997 Firehawk LT4
Taylor ignition wire crimp tool...
So, I bought a set of Taylor wires to make for on my '97 LT1 in my '80 IH Scout. I routed them along side the valve covers and dropped them to the plugs to clear my shorty headers, and all was going great. Until, that is, I got to the point of cutting and crimping on the terminals at the Opti end.
I actually began with the coil wire since it's still off the engine. Went step by step through the instructions provided by Taylor, and when I put the end in their little crimp tool, the two halves were within an inch of touching their "stops" when I hadn't even put it in the vise yet. I crimped them, and it didn't really look any different when I pulled the wire out of their tool. I gently tugged on the wire, and it popped right out of the terminal with no problem whatsoever. I tried again, with a repeat performance of the first time. What gives? Anyone else had any issues? Do I just crimp them with the tool (which isn't really doing anything special from what I can tell), then mash on 'em a bit more with a pair of pliers, or what? I've made Accel 8.8's in the past with no real issues, just using pliers. I figured I'd use the "pro" tool and try to make a set correct this time, and it got me nowhere but pissed off.
____________________
1997 LT4 Firehawk #009
1987 Trans Am 305 TPI-Stock running gear, but coolified looks! -For sale
1980 International Scout II with an LT1
05-27-2010, 03:09 PM #2Senior Member
- Feb 2006
- Orange County, NY
Can you post a pic of the crimp tool? I have done the accel's too with the tool they provide with no problem.
05-27-2010, 07:19 PM #3Member
- Apr 2006
- Bridgewater, VA
Same as this...
05-30-2010, 08:53 AM #4Senior Member
- Feb 2006
- Orange County, NY
When you seperated the two sections did you make sure to get that little lip off the one? If not it looks like it would keep it from going in all the way.
06-01-2010, 06:41 PM #5Member
- Apr 2006
- Bridgewater, VA
It mashes all the way down...still not a good crimp.
06-02-2010, 02:52 PM #6Senior Member
- Feb 2006
- Orange County, NY
Maybe grind the one piece down a little so it fits tighter. Have you contacted tayor about this? Maybe they have a video on their website. If I was doing wires several times I would invest in the tool. You can never have enough tools right?
Help: Key Ignition Wire +12 volt
By 1batt4u in forum Stereo and ElectronicsReplies: 3Last Post: 11-17-2014, 02:47 PM -
MSD super conductor ignition wire.
By weberje in forum General HelpReplies: 6Last Post: 09-05-2010, 06:50 PM -
I need 1 blue taylor plug wire :(
By 95GreenZ28 in forum Parts Wanted / TradeReplies: 0Last Post: 08-04-2007, 07:23 AM -
Taylor Wire+Ngk Plugs, Autometer Oil Pressure Gauge
By jmir14 in forum Parts For Sale / TradeReplies: 3Last Post: 05-18-2006, 06:28 AM -
Taylor 10.4mm's?
By LS1Power06 in forum General HelpReplies: 5Last Post: 03-21-2006, 06:41 PM
