10-04-2014, 07:15 PM #1Junior Member
- Oct 2014
- california
red- 2002 pontiac trans am
2002 trans am steering issue pls help...
I have replaced my rack and pinion 3 times and my pump 3 times and the car hasn't been able to drive down the road. I do as the manufacture is suggesting and pulling a vacuum on the pump at 20 in hg for 5 minutes and on top of that I have flushed the system changed the lines everything. If I have the front end in the air It has no problem however when I let the tires touch the ground and try to steer the pump locks up and I get a load noise and a loss of steering. When I shut the car off and restart it it will work fine again until I turn the wheels and it locks up. Im stumped I have swapped all the components 3 times unsure of the failure. Any one have any ideas thanks.
10-05-2014, 07:19 AM #211 years of bangin gears
- Jan 2009
- North Jersey
Have you inspected your power steering hoses to see if they are collapsing while the engine is running or while you are steering the car?
10-05-2014, 10:31 AM #3Junior Member
- Oct 2014
- california
I have and I replaced them everything is completely new. So today I found my issue and was able to drive the car. The issue was I was using oriellys parts. I found that after removing the pump this morning and taking it apart the shaft that the pully goes on had no snap ring holding it in position and allowed the gears to bind up and stripped the gear on the shaft. I used the 2 failed pumps and built 1 good one. I didn't want to get another pump from any were. Last night I removed the high pressure line and found that the check valve in the rack had come apart so I put the third rack in. I still had the same issue. This morning waking up furiously I removed the pump and rebuilt the pump myself and it now works. I don't understand why it is so hard to get quality parts from the auto parts store anymore.
10-05-2014, 10:33 AM #4Junior Member
- Oct 2014
- california
relieved and thanks for the responce
10-06-2014, 02:22 AM #5
Ugh. Sounds like a complete nightmare. I have always said that "new parts" do not necessarily mean "good parts". Glad you got it figured out.
10-09-2014, 04:00 PM #611 years of bangin gears
- Jan 2009
- North Jersey
Sounds like someone in their Quality Control division is asleep. How someone could half-ass rebuild a pump is beyond me.
Temperature Issue 2002 Trans Am WS6
By Zedtwentyeight in forum Firebird / WS6Replies: 4Last Post: 11-07-2011, 06:41 PM -
By Zedtwentyeight in forum General HelpReplies: 12Last Post: 11-07-2011, 05:58 AM -
Driver window issue 2002 Trans Am
By Jeronimo in forum Firebird / WS6Replies: 1Last Post: 03-27-2010, 12:07 PM -
Help: serious steering issue
By IT_SS in forum Camaro / SSReplies: 10Last Post: 11-11-2008, 08:07 AM -
Steering Issue
By hix5000 in forum General HelpReplies: 12Last Post: 05-21-2008, 05:58 AM
