Results 1 to 13 of 13
Thread: Steering Issue
    Phoenix
    94 Z28
    Steering Issue
    I have a little play in my steering wheel. It's not too noticable at city speed but on the highway it's definitely an issue.
    Where should I start looking to find the problem?
    94 z28 LT1
    Auto Tranny
    Junior Member pyrows666's Avatar
    san jose
    1989 formula 305
    I would start at your Tie rods for the PLAY. and double check the shaft of your steering column.. what does it do shake? side to side? vibrate. car goes one direction?
    SATX
    2000 Trans Am
    hes talking about steering wheel play, meaning the wheel has alot of play before the wheels respond. well ive never had that on a car, but on my diesel i adjust the U joints when that happens.
    Phoenix
    94 Z28
    Quote Originally Posted by hurraquio View Post
    Exactly. If I am driving the car I can shake the wheel from side to side an inch or so before the wheels respond.
    SATX
    2000 Trans Am
    yeah check your U-Joint(s) or the Yoke(s) when I get that in my truck ususally i just have to tighten a few nuts and its good to go.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    no its probablly the tie rods. What U-joints are you talking about?? The ones on the steering shaft between the column and steering gear?? Those aren't ever a problem on anything I've ever worked on
    Jan 2008
    columbus, ohio
    1999 T/A
    Yah my suggestion would be to check the outer tie rod ends. I've done allot of em on lt1 cars.
    Phoenix
    94 Z28
    Thanks for the tip. I'll check them this weekend and report what I find.
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    Intermdiate steering shaft could be it that would give you play but I think it would knock a little
    I flame retards CamaroFan71's Avatar
    Aug 2006
    Baton Rouge, La.
    QuickSilverMetallic
    2005 GTO M6
    Also try replacing that ragjoint with an actual metal one. Those wear out also.
    Calgary Alberta
    pewter
    1999 Trans Am
    I have the same problem with my TA. And it is the outer tie rods.
    Phoenix
    94 Z28
    Oops I forgot to update this. It is indeed the tie rods. Good call guys and thanks for the help!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    the LT1 cars have a rag joint for the steering column. if you still have some play after doing the tie rod ends, look into replacing that. there is a company that makes a solid aluminum replacement for the rubber insert.
    the LS1 steering shaft has u-joints.
  1. Question: Power steering issue
    By homickb in forum Suspension and Handling
    Last Post: 04-03-2012, 08:53 AM
  2. power steering issue
    By 99pewterta in forum General Help
    Last Post: 07-02-2009, 01:12 AM
  3. Yet another power steering issue
    By jamessr in forum General Help
    Last Post: 04-17-2009, 01:13 PM
  4. Help: serious steering issue
    By IT_SS in forum Camaro / SS
    Last Post: 11-11-2008, 08:07 AM
  5. Power steering issue
    By juiced99ws6 in forum General Help
    Last Post: 08-25-2005, 09:26 AM
