Results 1 to 11 of 11
Thread: Kill switch ideas
06-08-2014, 09:33 PM #1Junior Member
- Jan 2011
- Tucson,AZ
PEWTER- 2001 SS
Kill switch ideas
Just last night I went to my local track for test n tune. To my luck I couldn't make a run because I don't have a kill switch installed for my relocated battery in the rear. If anyone can steer me in a direction of ideas of where to install the actual switch in the exterior like the tech told me at the track. Any help will help and if you guys have any pictures that will be awesome, thanks in advance for your input.
06-12-2014, 11:06 AM #211 years of bangin gears
- Jan 2009
- North Jersey
I have seen the kill switch installed in a taillight or rear filler panel. If you want to go stealth, under the rear bumper.
06-12-2014, 07:24 PM #3
06-13-2014, 04:52 AM #4
If you want to pass NHRA tech the switch will have to be easily accessable and clearly marked.
I've wen't over this a few times on the board here. Seems people thought it was cool to relocate the battery on their street cars and then found out they couldn't get through tech at the track because of an improper (or lack of) a sealed battery box, not venting fumes properly, or the lack of a cutoff switch.
06-15-2014, 07:36 AM #5Junior Member
- Jan 2011
- Tucson,AZ
PEWTER- 2001 SS
06-15-2014, 07:38 AM #6Junior Member
- Jan 2011
- Tucson,AZ
PEWTER- 2001 SS
06-15-2014, 08:04 AM #7
That would be the best solution if we are just talking about a 99% street car that only sees track time once or twice a year. With very little track time the benefits of the battery in the rear vs all the hassles you have to deal with in doing so isn't really worth the effort. Not to mention you loose your spare tire storage space, which isn't really a good idea on a street car either.
Unless you have a vert, you don't have a trunk and that poses another issue. I'm not sure the NHRA would consider that plastic spare tire cover as protection from the battery. With a hatch back all that space back there is considered passenger compartment and isn't seperated with a piece of sheetmetal (like a trunk) So technically in that case the battery has to be contained in an NHRA approved sealed box, then a hole must be drilled with a hose connection that vents fumes outside the car (usually through the bottom of the floor pan)
So not only is having a kill switch an issue, but there are other guidelines. The NHRA even dictates what size the bolts need to be to fasten the battery and how it should attach to the floor. Depending on how picky your tech official wants to be. If they follow everything to the letter you'll be spending some money to get through tech.Last edited by Firebirdjones; 06-15-2014 at 08:06 AM.
06-17-2014, 06:11 AM #8Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
06-18-2014, 03:31 AM #9
06-18-2014, 03:40 AM #10
And if your wondering, has ran 11.38 but 11.50 up keeps us legal (no bar yet)
06-19-2014, 10:59 AM #11Junior Member
- Jan 2011
- Tucson,AZ
PEWTER- 2001 SS
Question: Kill switch
By 98maro in forum General HelpReplies: 30Last Post: 03-21-2011, 09:51 AM -
Kill switch?
By Spikito in forum Stereo and ElectronicsReplies: 24Last Post: 04-18-2010, 11:45 AM -
Help: Kill switch
By 98maro in forum General HelpReplies: 0Last Post: 04-13-2010, 01:57 PM -
Kill Switch
By tep98ws6 in forum Stereo and ElectronicsReplies: 7Last Post: 07-13-2009, 08:30 PM -
I need ideas on how to kill a cat!
By nitrox28 in forum Almost Anything GoesReplies: 37Last Post: 05-27-2007, 02:42 PM
