Results 1 to 20 of 25
Thread: Kill switch?
03-09-2010, 10:40 PM #1James Bond
- Aug 2007
- Texas
Kill switch?
Im very paranoid about my car getting stolen, I don't know why.
Anyway, I was wondering if there's a simple way to put in a kill switch, just a toggle switch somewhere, if its on, the car will start, if its not, the car wont.
Id kind of like it to be effective against hot wiring as well, I dont know if i can just reroute the hot ignition wire to a switch somewhere.
03-10-2010, 07:16 AM #2
Sure can. Under your console is your neutral safety switch (auto). Get a volt meter or ask around to determine which wire is the "start" hot wire. Cut it and add a switch. You can then shut off the ability to fire the engine up with or without keys. Or splice a switch on the clutch switch wires. That way even with the clutch pressed to the floor it won't fire up.. Turn your switch on and push the clutch in as usual to start it. Kinda like a bypass but for sorce power only. You could hide a pressure switch (like what is used on the doors for dome lighting) under the ashtray. When the ashtray is in the car will start. Then you could just remove the ashtray and the car will not start..
03-10-2010, 07:26 AM #3Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
03-10-2010, 07:40 AM #4
Like this:
03-10-2010, 08:24 AM #5Electrical Engineer
- Jul 2009
- North of the Motorcity
+1
You can tap either wire involed in the circuit (depending on the ciruit), it doesn't have to be the "hot" wire. It acheives the same goal, which is opening the ciruit. I would do something simple and low amps like the ideas stated above, I wouldn't try switching things like the starter wire itself (for many reasons).
As far as hiding it goes, the best idea I have heard of was a friend of mine had a push button hidden underneath the carpet and he used his food to activated/deactivate it. It was up underneath the pedals, so it couldn't be touched while driving. I have heard of people who actually have put kill switches on the outside of the cars as well as underneath the hood.
I'd also keep in mind the paths a car theive takes to hot wire your car. If you place your splice in this path, it will be obvious to person who knows how to hot wire and they could simple trace it if it's run to an obvious place.Last edited by KMdef9; 03-10-2010 at 08:27 AM.
03-10-2010, 08:34 AM #6
03-10-2010, 08:44 AM #7Electrical Engineer
- Jul 2009
That does make it easier to identify, for sure!
I guess it all depends on how much hiding of the wires the OP wants to do. I'm not sure the path of each wire involved with starting the car, so I'd try to find the most hidden wire possible, something buried underneath multiple things, wrapped in protective insulation. Not something right where a thieve would rip off a piece of plastic and see your splicing. With that said, you can easily hide it by wrapping in some electrical tape and insulation to make it appear OEM, might throw them off. Anything worth doing is worth doing right, but that's me over analyzing things...
03-10-2010, 12:58 PM #8James Bond
- Aug 2007
- Texas
well if you take off the panel under the steering wheel, all the wires going up the column are right there....ive spliced stuff into my ignition wire before, like my radar, so itll come on when i start my car, and turn off when i kill it. but, if someone were to hotwire my car, theyd see it.
im liking the idea for the clutch switch....something so that itll think the clutch isnt pushed, when it really is.
as where as where to put it...i have no idea. im thinking a inconspicuous momentary switch somwhere,
I could put it on the end of my blinker, where the cruise button would go, lol
03-10-2010, 08:25 PM #9
Not sure what the Firebirds have, but for a Camaro, you could purchase another fog light switch and put it in near the real fog light switch. It would look factory and much more inconspicuous than a metal toggle switch.
03-10-2010, 08:28 PM #10
03-10-2010, 10:18 PM #11James Bond
- Aug 2007
- Texas
that may work...only problem is i have a BASE model car, lol....both of those switches are dummies on mine...the plastic is just molded to look like a button
03-10-2010, 10:30 PM #12
03-10-2010, 11:07 PM #13James Bond
- Aug 2007
- Texas
true....id have to figure out how to install it though, lol...since mines fake....ill take it apart friday
03-11-2010, 10:04 AM #14
put it in plain sight and they will never figure it out LOL
see I would do a set of relays and make the switch power the fuel pump circiut, starter ignition circuit, and the injector circuit. LOL those poor bastards would not figure it out even if they had a week to steel the car. lol
03-11-2010, 11:01 AM #15James Bond
- Aug 2007
- Texas
ok so does anyone know where this clutch switch is? lol
03-11-2010, 11:04 AM #16
03-13-2010, 04:42 PM #17
03-18-2010, 01:56 PM #18
Kill Switch
I got two of these and they work just fine:
http://www.killswitchcentral.com/
David in AZ
03-30-2010, 11:57 AM #19Junior Member
- Jul 2006
- Cedar, KS
Pewter Metallic- 2000 NHRA Trans Am
How about this?
This is what I am putting in... Yeah.. little over the top but why not?!
Biometric lock
03-30-2010, 01:41 PM #20James Bond
- Aug 2007
- Texas
i dont see a problem with that, lol
Help: Kill switch ideas
By tangkiller_z28 in forum General HelpReplies: 10Last Post: 06-19-2014, 10:59 AM -
Question: Kill switch
By 98maro in forum General HelpReplies: 30Last Post: 03-21-2011, 09:51 AM -
Help: Kill switch
By 98maro in forum General HelpReplies: 0Last Post: 04-13-2010, 01:57 PM -
Kill Switch
By tep98ws6 in forum Stereo and ElectronicsReplies: 7Last Post: 07-13-2009, 08:30 PM -
Kill Switch Issue??
By tbaum in forum General HelpReplies: 3Last Post: 12-08-2007, 07:29 PM
