Results 1 to 2 of 2
Thread: OE Connecting Rods
05-27-2014, 04:37 AM #1
OE Connecting Rods
I am hearing conflicting reports on if this is right, but we had a guy order LS1 rods and the caps on the bottom aren't separated from the rod itself. I'm hearing the customer has to "break" the rod apart, but that's hard for me to get my head around. Anyone know for sure?
05-27-2014, 05:04 AM #2Spaz is My Mentor
OE Connecting Rods
yes all oem rods will need to be cracked. It's how they are made. If you feel uneasy about doing it then by al means have a shop do it. It shouldn't cost much to do. All it takes is clamping in a vice in the correct postion and apply force.
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
Wanted: LUNATI LTE1 connecting rods!
By JAX04 in forum Parts Wanted / TradeReplies: 0Last Post: 05-03-2011, 04:45 AM -
Connecting rods?
By 1999sscamaro in forum Internal EngineReplies: 4Last Post: 09-11-2010, 07:18 AM -
Do 6.0 connecting rods all face the same way?
By wsm9808 in forum Internal EngineReplies: 1Last Post: 08-17-2009, 03:39 AM -
Question: LS1 LQ9 Stock Connecting Rods
By LSP1 in forum Internal EngineReplies: 5Last Post: 05-17-2008, 09:55 AM -
Connecting rods with SC
By Transam388 in forum Forced InductionReplies: 2Last Post: 02-13-2006, 08:27 AM
