Results 1 to 2 of 2
08-04-2009, 07:25 PM #1Junior Member
- Aug 2009
- texas
Do 6.0 connecting rods all face the same way?
I have a new 6.0 block and a seperate set of new, take-outs, 6.0 rods and pistons that came with it as a basket case.
While installing the pistons I noticed all the rods are (factory) hung on the pistons facing the same way. IE, with the dots on the pistons facing the front of the block, the rods all end up facing the same way.
Is this correct? I am used to engines where the rods have the bearings offset in the rods, and then installed with the offset facing the crank radius. You then have 4 on one bank facing one way and the other 4 facing the opposite way on the other bank.
Thanks, Scott
08-17-2009, 03:39 AM #2
yes all the same direction.
OE Connecting Rods
By NoQuarter in forum Internal EngineReplies: 1Last Post: 05-27-2014, 05:04 AM -
Wanted: LUNATI LTE1 connecting rods!
By JAX04 in forum Parts Wanted / TradeReplies: 0Last Post: 05-03-2011, 04:45 AM -
Connecting rods?
By 1999sscamaro in forum Internal EngineReplies: 4Last Post: 09-11-2010, 07:18 AM -
Question: LS1 LQ9 Stock Connecting Rods
By LSP1 in forum Internal EngineReplies: 5Last Post: 05-17-2008, 09:55 AM -
Connecting rods with SC
By Transam388 in forum Forced InductionReplies: 2Last Post: 02-13-2006, 08:27 AM
