Thread: 1999 Z28 Throttle Body Bypass
05-17-2014, 03:08 PM #1
So I want to do the throttle body bypass on my car but I wanted to know if rather than using the the hose connector would it be possible just to use 1 longer hose? Anybody know if any hose from a different car will work for this purpose?
05-17-2014, 05:59 PM #2
I used a piece of coated brake line and fabbed a bypass on our car - works great and doesn't look too bad. I don't know of a specific hose application that can be used for this purpose.
05-18-2014, 04:13 AM #32010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
05-18-2014, 10:09 AM #4
Here are a couple of pics of how I bypassed the throttle body on our car. In the first pic, you can see that it attaches to the crossover tube with a rubber line. If you look closely, you'll see a union under the sheath where the tubing size changes over to match the radiator. The second pic shows it routed under the air inlet and to the radiator where it again has a rubber hose for the connection.
throttle body bypass on lt1
By jimmybling31 in forum External EngineReplies: 6Last Post: 03-18-2008, 05:28 PM -
Throttle Body Bypass?
By Demon_Z28 in forum External EngineReplies: 5Last Post: 03-10-2008, 03:42 PM -
Throttle body bypass?
By 97ramair in forum External EngineReplies: 13Last Post: 12-05-2007, 10:44 AM -
throttle body bypass............
By clg82 in forum Firebird / WS6Replies: 3Last Post: 04-29-2007, 12:54 PM -
Throttle body Bypass kit ? 6-8hp?
By jinxeng in forum External EngineReplies: 17Last Post: 09-18-2006, 08:37 AM
