    Orlando, FL
    Mean Black
    What is the widest tire that I can put on a stock 5 spoke
    Hi guys. I might have to keep my stock rims after all. So I'm in need of two new tires for the rear and I was thinking about maybe getting a wider tire. I currently been using 245/60Z R16. What is the widest tire I can use that will look good in a 5 spoke 16 inch rim? Thanks.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    How wide are the 16s? If they are 9" the widest I would go is 275, 285 or 295 if 9.5" depending on the tire.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Orlando, FL
    Mean Black
    Im not sure how wide they are. I know the are the oem ones. I have two extra rims. I will look and see if it is stamped on the rim somewhere when I get home.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    The problem with 16" wheels is the limited tire sizes. Widest I think they make is a 245 or 255.
    Orlando, FL
    Mean Black
    ok so the OEM 5 spoke wheels are stamped 16 x 8. So 255 is the widest I can go?
    Apr 2010
    Alabama
    Black/ Silver
    If they make 265s for 16s you could probably do that otherwise 255s is the widest I would go.
    Orlando, FL
    Mean Black
    Ok ty.
    Apr 2010
    Alabama
    Black/ Silver
    If you want wider you could get a set of 17" stock wheels and you can go up to 295 on certain tires. I have a set of 17s I don't need and you can have them for cheap if you want.
    Orlando, FL
    Mean Black
    Sounds good but im afraid shipping is going to kill me
    Apr 2010
    Alabama
    Black/ Silver
    What is your zip and I'll check to see.
    Orlando, FL
    Mean Black
    Send me a pm. 34744
    Apr 2010
    Alabama
    Black/ Silver
    Pm sent.
  1. smallest tire on a stock SS 5 spoke?
    By newtownhood in forum Wheels and Tires
    Last Post: 07-11-2014, 12:50 PM
  2. What is the widest tire I can run?
    By INeedLS1 in forum Wheels and Tires
    Last Post: 12-21-2009, 06:11 PM
  3. Question: Widest tire on 9 inch (stock) rim???
    By Musclecargt71 in forum Wheels and Tires
    Last Post: 08-22-2009, 05:19 PM
  4. widest tire
    By Nitro_Junkie97 in forum Almost Anything Goes
    Last Post: 04-03-2008, 03:15 PM
  5. widest tire
    By 96t/a in forum Wheels and Tires
    Last Post: 11-03-2007, 03:44 PM
