Results 1 to 20 of 21
    Junior Member jefff82's Avatar
    Feb 2014
    kingman az
    do you need spacers for c5 wheels on 99 firebird
    i have a 99 formula. found a smoking deal on some c5 thin spoke wheels with tires. ive read that you need spacers and have read that you don't need them. looking to get a definite answer to see if I need to buy spacers or not. the wheels are the 17 in front 18 in the rear 5 spoke wheels off a 03 corvette I believe.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    No spacers needed. You might trigger the abs light with the difference in diameter though.
    Feb 2014
    kingman az
    Quote Originally Posted by bigrondownhiller View Post
    Why would rims mess with abs
    Feb 2006
    Orange County, NY
    always dirty
    Its the difference in overall diameter between the front and rear that causes the problems.
    Feb 2014
    kingman az
    never thought of that. have seen so many birds/Camaros running these didn't think there would be any issues. what problems does it cause. I hate dash lights
    Feb 2006
    Orange County, NY
    always dirty
    I guess some people don't mind it. Probably the light and lack of abs.
    Feb 2014
    kingman az
    can u fix it so the lights don't pop up without changing the wheels back to stock
    Feb 2006
    Orange County, NY
    always dirty
    I haven't heard of anyone doing it. If you put a tall enough tire on the front to keep the difference minimal you should be fine.
    Feb 2014
    kingman az
    I did the math with the 245 45 17 = 25.68
    275 40 18 = 26.66
    will that make the light come on you think
    275 35 18 = 25.57
    does it matter if I go thinner in rear. the rears will be replaced first
    Feb 2006
    Orange County, NY
    always dirty
    If you go with the 275 35 18 in the rear you shouldn't have a problem, only .1 inch difference. With the 40 series there is an inch difference. You should also check the specs on the tires you are going with. There might be a slight difference.
    Feb 2014
    kingman az
    difference in what specs
    Feb 2006
    Orange County, NY
    always dirty
    The actual diameter depending on tread depth. It will probably be miniscule though.
    Feb 2014
    kingman az
    thanks I would have been mad seeing my lights coming on and not knowing why. found some 275 35 18 tires for 270 out the door mounted and balanced. that was the best I could find
    Feb 2006
    Orange County, NY
    always dirty
    Just look for some pictures of cars with the different rims. Make sure you like the look with the shorter sidewall tire on the rear. Not sure if you will be able to see a difference.
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    Youll need to do the BFH mod to the rear inner fender wells.
    Aka pound in a little portion of the inner fender wells to clear the rear tires when hitting bumps
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    I'm running the N73 wheels with Nitto 555 tires in 245/45ZR-17 and 275/35ZR-18 with no problems at all. The overall diameters on the front and rear are close enough that I have not had any issues with traction control or braking. The N73s have a slightly different backspacing than yours which puts them inboard a little more but I have not had any issues with rubbing or bumping the suspension.
    Feb 2014
    kingman az
    So the wheels do rub on bumps. Has any body ran adapters. If so how big. And do you have trim the studs down. Was looking at a 1" adapter but didn't know if stock studswould be too long. Don't want to trim down studs. Will the 275 stick out too far with the adapters
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    If you are talking about rubbing on the inside against the wheel well, as b.lee posted, you might be able to make adjustments with a soft mallet on the wheel well. Make sure if you accidentally remove any paint that you recover it to prevent future rust. Also, are you using the taller bump stops that come stock on cars with 17 inch wheels? All of the SS and WS6 cars have taller bump stops than the cars with 16 inch wheels to help prevent rubbing. You can get these aftermarket in rubber or poly urethane with the correct spacers.
    Feb 2014
    kingman az
    Quote Originally Posted by sjgreen6 View Post
    If you are talking about rubbing on the inside against the wheel well, as b.lee posted, you might be able to make adjustments with a soft mallet on the wheel well. InMake sure if you accidentally remove any paint that you recover it to prevent future rust. Also, are you using the taller bump stops that come stock on cars with 17 inch wheels? All of the SS and WS6 cars have taller bump stops than the cars with 16 inch wheels to help prevent rubbing. You can get these aftermarket in rubber or poly urethane with the correct spacers.
    Mine came with 16's stock. So stock bumpstops.would rather space it out than beat the inner fender well I guess
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    It might be a cheap solution to your problem without breaking out the hammer. I'm not sure if any of our sponsors carry they but you can get them from KY Speed for a little more than $25.00. They are just a bracket that sits under your current bumper to increase the contact height. All of the 4th Gen F bodies that came with 17 inch wheels had them from the factory.
  1. Question: Spacers on Corvette Y2K Wheels
    By Theman44 in forum Wheels and Tires
    Last Post: 12-10-2012, 09:58 AM
  2. Will 1 inch spacers work on my 56mm offset wheels?
    By 5abivt in forum Wheels and Tires
    Last Post: 02-21-2010, 08:51 AM
  3. 1 1/2" spacers for C6 Corvette wheels...
    By Stevenix in forum Wheels and Tires
    Last Post: 08-19-2009, 02:43 PM
  4. Help: wheels for my firebird?
    By larryndog in forum Wheels and Tires
    Last Post: 07-30-2008, 07:47 PM
  5. Spacers,Firebird Rear-Jounce-Bumper
    By blackTA6585 in forum Wheels and Tires
    Last Post: 03-10-2006, 11:37 AM
