Results 1 to 10 of 10
    Senior Member
    Toronto
    SOM
    2002 SS
    Will 1 inch spacers work on my 56mm offset wheels?
    ANyone use the bolt on type spacers on a 56mm (c4 vette offset) rims? I need to bring the wheels out a bit and was wondering if the tire might rub on the fender when going over bumps. with sportlines and the stock wheels w/winters the car looks totally asss with how far in the wheels are on the rear.
    I was thinking 3/4" spacers would be ideal but i dont think there are bolt on types in this size as the threads would probably be too long.
    01 z28
    I would highly recommend not using any spacers period. They are known to shear off wheel studs. If you are just dead set on using spacers, I would get a set of hardened studs and install them just to be on the safe side.
    Dec 2009
    Croydon, PA
    rust
    65 Impala SS Convertible
    Not a fan of spacers here either.
    Senior Member
    Toronto
    SOM
    2002 SS
    Just looked at some pics with the zr1 wheels on the car and wow 1" would be way too big. the offset of the stock 01 16s is just horrible and makes it look like it could used a 2" spacer on the back. I think I may go with 1/4 inch or 3/8 in the rear.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    FYI
    There's slip on wheel spacers, and there's bolt on hub spacers. The bolt on hub spacers are completely safe, and slip on wheels spacers put undo stress on the wheel studs.
    Ca.
    Navy Blue
    1999 Camaro Z28
    Quote Originally Posted by 5abivt View Post
    01 z28
    How wide are the wheels?
    H&R makes 20mm hubcentric hub spacers.
    Senior Member
    Toronto
    SOM
    2002 SS
    Quote Originally Posted by Blue28 View Post
    Wheels are 9.5 wide. theyre the c4 zr1 style wheels. 20mm sounds perfect I think I'll go with that.
    Senior Member
    Toronto
    SOM
    2002 SS
    20mm is way bigger than I thought. I believe 8mm is a 1/4 inch or close to it. Do you guys know if we have enough threads not to need longer studs with an 8mm spacer?
    Ca.
    Navy Blue
    1999 Camaro Z28
    19mm = 3/4"
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    I would go w/ a 1/4" making it quite ideal.
    Make sure you have long enough studs for that.
    Eugenio_SS
  1. Question: will these work im not sure of back spaceing or offset
    By devildogws6 in forum Wheels and Tires
    Last Post: 03-10-2013, 08:50 AM
  2. 1/2 inch spacers
    By MRM 01 in forum Wheels and Tires
    Last Post: 04-28-2010, 07:51 PM
  3. Will this offset work?
    By [email protected] in forum Wheels and Tires
    Last Post: 12-04-2008, 10:41 PM
  4. CNC billet wheel spacers 3/8 inch $45 shipped
    By BlownC5 in forum Parts For Sale / Trade
    Last Post: 07-02-2008, 08:19 AM
  5. 1/4 inch billet aluminum wheel spacers $30 shipped
    Last Post: 09-12-2006, 05:21 PM
