03-04-2013, 03:37 PM #1
03-04-2013, 04:17 PM #2Senior Member
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-04-2013, 05:39 PM #3
The only reason i say the bolt pattern would work is there are a few guys on here that run with after market bmw rims but the whole hub ring thing has me worried thats a big difference. I honestly not sure what that is?
03-06-2013, 08:24 AM #4Senior Member
- Apr 2010
- Alabama
The hub ring size on a wheel is the part on the inside of the wheel that the hub goes in. If it is too small the wheel won't fit and if it is way too big it may not rest correctly. You would need an adapter in this case. Slightly bigger would be fine without one but in this case I would say an adapter is definitely needed.
03-06-2013, 12:53 PM #5
03-08-2013, 10:30 AM #6
Those wheel offsets(+43) are perfect for a F-body, yeah technically you shouldn't use a wheel with a different bolt pattern spacing, but in this case the difference is so small the the studs will only be off by .35mm(.0128") at each lugnut hole. So in all but the most extreme conditions you should be perfectly fine.
Otherwise just get 4 hubcentric rings so the wheels center up an drive on.
BTW there's a lot of different wheel styles available with the 5-120 bolt pattern.
03-09-2013, 04:35 PM #7
i called them up and all i need is hub ring adapters which i found that fit the 70.3 to 72.56
03-10-2013, 08:50 AM #8Give me a place to stand.
- Jul 2008
- Jacksonville, FL
Red- 2000 SS '89 IROC-Z
Let me know how they work, that looks good!
Will 1 inch spacers work on my 56mm offset wheels?
By 5abivt in forum Wheels and TiresReplies: 9Last Post: 02-21-2010, 08:51 AM -
Lab work is back on Castrol Edge
By Sarge in forum Almost Anything GoesReplies: 36Last Post: 02-23-2009, 12:25 PM -
Will this offset work?
By [email protected] in forum Wheels and TiresReplies: 16Last Post: 12-04-2008, 10:41 PM -
Going back to work advice?
By redls1 in forum Almost Anything GoesReplies: 13Last Post: 07-07-2008, 08:23 AM -
Is this offset ok to use?
By NavyZ in forum Wheels and TiresReplies: 0Last Post: 03-25-2006, 10:12 AM
