04-07-2014, 09:19 AM #1
problems with SLP LEVEL II springs
i had replaced my orginal springs with SLP Level II (300/450 springrate) last winter.
so i drove my car for the first time after the winter, and i heard a problem (metal to metal)
so i looked at my front springs and i see the spring is hitting the upper bolt form the upper control arm, this problem is on both sides.
i checked it several times if i did make a mistake putting the spings on, but i can't see anything wrong.
do i miss something ?
it's the left bolt on the picture
04-07-2014, 04:54 PM #2
- Jun 2011
- Branchville, NJ
You may have the bolts on backward. Try putting the nut on the outside, I think you will have the room to clear the spring.
04-07-2014, 08:03 PM #3
Thanks 2002SLP for the responce, you mean the bolts from the upper arm ?, they have never been loose
I solved the problem yesterday evening, i released the spring, and moved up the strut a little bit (i don't know the right name, the rubber thing on top), so now i have a little bit of clearance
04-08-2014, 04:40 AM #4
V6 Camaro/Firebird with Hotchkis or SLP Level II springs
By pv-camaro in forum V6Replies: 8Last Post: 01-06-2014, 01:17 PM -
level 3 trans vs a level 5 rebuilt kit
By FMR_TransAm in forum General HelpReplies: 5Last Post: 03-18-2012, 09:13 PM -
Stranos & SLP Level II springs?
By mcnoskyimages in forum Suspension and HandlingReplies: 21Last Post: 07-13-2010, 12:19 PM -
Fuel Level Gauge Problems
By supercharged666 in forum General HelpReplies: 11Last Post: 11-12-2008, 02:28 PM -
TODAY SALE, LEVEL 2 $100 OFF, LEVEL 3 $300 off
By performabuilt in forum Automatic TransmissionReplies: 1Last Post: 05-21-2008, 01:47 PM
