Results 1 to 20 of 22
    Junior Member mcnoskyimages's Avatar
    Jun 2010
    DFW
    2002 Camaro Z28
    Stranos & SLP Level II springs?
    What are the differences?
    Life In The Fast Lane..!! redracer1's Avatar
    SoCal, SD
    Brickyard 400 Trac Car#10
    35th Camaro SS/LE Vert
    Quote Originally Posted by mcnoskyimages View Post
    Strano
    F:550 lbs R:150 lbs non progressive rate, much easier for the shock to dampin the compression & rebound stroke.
    1.25" lower ride height, track tuned and tested...needs a good shock.
    SLP
    F:300-450 lbs R:115-185 progressive rate, more difficult for shock to dampin the compression & rebound stroke.
    .50" lower ride height, ??? about track time...??? shocks
    Jun 2010
    DFW
    2002 Camaro Z28
    Awesome! Exactly what I wanted to hear. Thanks.
    Member xmarkx's Avatar
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    does edelbrock still make springs for 4 gens? I remember hearing people talk about them making the car real low but I haven't heard anything about them in a while
    Senior Member
    texas
    2000 formula
    i think eldebrocks are re packaged eibachs
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    Quote Originally Posted by sjsingle1 View Post
    I thought that was SLP who just took eibachs and painted them black. eibachs been busy lol
    Member pv-camaro's Avatar
    Dec 2008
    Netherlands (europe)
    Light Pewter (11)
    2001 Camaro
    Quote Originally Posted by redracer1 View Post
    Strano
    SLP
    maybe a stupid question:
    Can i use the "SLP springs" for a 2001 3.8V6 Camaro, Koni 's are already on the car.
    I don't want the car to low, i am living in the Netherlands (Europe) and in city's here are a lot of speed bumps, but i need some stiffer springs.
    but most of the stiffer springs are lower 1,25" to 2" (eibach, Strano's).
    Member 00ls-1's Avatar
    Feb 2010
    Kilgore Texas
    2000 z28
    I'm gonna say yes about the springs on a v6 because I know you can take the v6 factory spring and put it on a z28
    Jun 2010
    DFW
    2002 Camaro Z28
    You can but keep in mind that they are designed for having the weight of a V8 on them. Without that weight they my feel stiffer than normal. But mechanically, they'll fit. They will lower the car but not as much ad Eibachs and Stranos.
    SoCal, SD
    Quote Originally Posted by pv-camaro View Post
    Also take a look at Hotchkis there only a 1" drop.
    and if you want a better handling car after that look at set of larger sway bars.
    Please don't post direct links to non sponsors
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    i do already have SS-swaybars (32-19) with Koni's Single adjustables.
    I am never been in Amerika, but here in the netherlands, almost in all city's (living area's) we have speed bumps, and they are different in height.
    so i can't take to much drop, 1" with Hotchkiss is maybe a solution,
    SoCal, SD
    Oops please don't me
    Koni's are awsome.
    SS bars are better but 35-22 are best. I guess what I was getting at is if your looking for better performance and you cant go to low but want to handle better a set of 35-22 mm sway bars is a good solution. Some guys stay on stock spring use the lower perch that are an option with the Koni's and do the hose mod on the rear springs for a 3/4" drop.
    We have speed bumps too but just mostly in parking lots and ya they suck.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Those SLP will offer little to no drop up front, but would be a big improvement over the stock V6 spring rates, and would be a good candidate for using the koni lower spring perch up front, since they offer very little drop up front. And as already stated the Hotchkis springs are also a good option for a 1" drop.
    IMO, if you can try stopping once you front wheel go over a bunch of these different speed bumps, when traffic permits it to get a good visual idea of how much ground clearance you can feel safe sacrificing.
    Jun 2010
    DFW
    2002 Camaro Z28
    Heres a pic of my car with the SLP's and Bilsieins. It is really more of a leveling kit. I lowers the rear anywhere from 1.5-2 inches and the front about .5-.75. Just enough to get the 4x4 out but not compromise clearance.
    Stock:
    http://mcnoskyimages.smugmug.com/Car...84270216_Umh9J
    SLP:
    http://mcnoskyimages.smugmug.com/Car...43995696_xFtgX
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    I think we have tge same wheels.. BC smoothies?
    Jun 2010
    DFW
    2002 Camaro Z28
    I liked them at first but they looked more and more like flowers the more and more I looked at them. Plus I had a bit of an issue with the first set I got.
    http://mcnoskyimages.smugmug.com/Car...31475579_4vYSS
    The other 3 we showing stress fractures. Someone F'ed up. The second set was a completely different design.
    Feb 2010
    Kilgore Texas
    2000 z28
    thatswhat i think of the first factory dodge 20s look like sunflowers lol
    Mar 2010
    EAST bay area Cali
    1999 camaro SS
    I'm with you on the flower thing. I hate these ugly ass wheels. they were on the car when I got it. after my bank account heals from my latest suspension purchases, the first thing I will be doing is buying new wheels
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    Thanks for all the info so far,
    Still have 2 questions:
    1, this are the SLP springs i can order by Summit racing (SLP online is difficult to order from the Netherlands, Summit is easier, i ordered several times already), are these the ones we are talking about, in the recent topic ?
    2, i have a list of spring rates, which one are these ? the level 1 or the level 2
    SLPonline and Summit racing, didn't show any spring rates on their website
  1. problems with SLP LEVEL II springs
    By pv-camaro in forum Suspension and Handling
    Last Post: 04-08-2014, 04:40 AM
  2. Replies: 8
    Last Post: 01-06-2014, 01:17 PM
  3. Springs - BMR vs. Stranos
    By Head Hunter in forum Suspension and Handling
    Last Post: 09-14-2010, 05:04 AM
  4. Stranos springs installed
    By naperws6 in forum Suspension and Handling
    Last Post: 09-30-2008, 09:28 PM
  5. TODAY SALE, LEVEL 2 $100 OFF, LEVEL 3 $300 off
    By performabuilt in forum Automatic Transmission
    Last Post: 05-21-2008, 01:47 PM
