    Member RichWS6's Avatar
    Tucson AZ
    2001 Pontiac Trans am WS6
    Fuel injector question
    I was just wondering, I am upgrading my injectors up to 42lb from the 26 I am pretty much pushing the 26's past they 80% mark and I don't want one to up and fail on me driving down the road. That being said when I replace them will they run fine swapped for that short time until I can get it tuned or should I drive it up as it is then swap them at the dyno and tune it? I looked through all the other threads about it and never found an answer about it so I figured I would ask.
    Firebird Firebird
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    What other mods have you done to the car. Just upgrading the injectors will not do very much for performance.
    Tucson AZ
    Quote Originally Posted by 2002ssslp View Post
    I got a Torquer V3 camshaft. 231/234 .643/.598 111°LSA decently ported ls1 heads. Headers and 3" exhaust all the way back, with my tune though I hit 85% load on the current injectors, it's not really a matter of power gains rather than reliability
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Injectors that size over stock will not run properly without a tune. I would drive the car to where ever you are getting it tuned and swap them on after they get it all hooked up and everything.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Jun 2011
    Branchville, NJ
    Silver & Blue
    Quote Originally Posted by RichWS6 View Post
    You will need to tune your ride asap. You are correct in upgrading to larger injectors because running lean will kill your motor. Sounds like a fast ride.
    Senior Member kingls1's Avatar
    Apr 2011
    Johnstown,PA
    1999 Trans-Am, 2012 Sonic
    I was told by Frost if changing injectors NOT TO RUN IT with the new injectors until the tune is in place for them
    99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
    Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
    Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
    Wish list.
    Coil overs, Heads & Cam
    Tucson AZ
    Thanks for the input I am going to get it tuned this weekend.
  1. fuel injector question
    By 1998 T/A in forum External Engine
    Last Post: 03-11-2015, 11:15 AM
  2. Fuel injector question
    By SOMTRANSAM in forum Almost Anything Goes
    Last Post: 08-12-2012, 11:33 AM
  3. Fuel Injector Question
    By sscamaro2000 in forum External Engine
    Last Post: 01-10-2009, 05:29 AM
  4. Bosch fuel injector question
    By koolaid_kid in forum LT1
    Last Post: 09-13-2006, 07:29 PM
  5. Fuel Injector Question
    By rbrack in forum External Engine
    Last Post: 02-28-2006, 06:53 PM
