Results 1 to 20 of 22
    Junior Member SOMTRANSAM's Avatar
    Feb 2012
    Long Island, NY
    Sunset Orange Metallic
    2001 Trans Am
    Fuel injector question
    I am trying to buy new fuel injectors and i am unsure on what fits in the ls1 cars. I want to get a good set of like 36lb or 42lb injectors. i was thinking of just buying the stock cobra injectors but i do not know if it fits.
    The L67 and L32 injectors are 36 pounders and fit perfectly. Can get them at a dealer or anyother good GM parts place. Why are you getting bigger injectors?
    Feb 2012
    Long Island, NY
    2001 Trans Am
    apparently i am just about maxing out the stock injectors and my car seems to have a loss in power somewhere so i am getting a bigger maf and injectors.
    Feb 2012
    Long Island, NY
    2001 Trans Am
    but also i wont need any adapter with those injectors right? they should just be a clean swap?
    Minnesota
    '10 ZR1
    Quote Originally Posted by SOMTRANSAM View Post
    Did you have the car on a chassis dyno? If so, what did your results look like? (hp/tq/ & air/fuel ratios)
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    IIRC, injectors are somewhat like spark plugs in that most have a common thread size. Might be wrong but I'm pretty sure that GM and Ford can be swapped...
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
    Op your same thread topic in the General Help section also has some replies you need to see.
    Feb 2012
    Long Island, NY
    2001 Trans Am
    car has been on a dynopak which bolts to the hubs. it made only like 356hp and 364tq which in my opinion is very low for a cam only LS1 with full exhaust and a stall
    Minnesota
    '10 ZR1
    Quote Originally Posted by FasstChevys View Post
    What did your results look like? (air/fuel ratios)
    In bold........
    also, I don't think a stall converter is going to increase your hp & tq (could be wrong, maybe a little if the converter is lighter weight)
    Feb 2012
    Long Island, NY
    2001 Trans Am
    even without the converter a cam only ls1 with full bolt ons should make way more power and my AFR is 13.4 I believe
    Minnesota
    '10 ZR1
    That seems to be a decent AFR - if you put more injector in it, how do you intend on moving more air?
    356 to the wheel is approximately 430 to the crank - that doesn't seem horrible to me.
    Feb 2012
    Long Island, NY
    2001 Trans Am
    my car is getting beat by a camaro with just full exhaust and i have full exhaust, cam and a stall that seems pretty bad to me lol
    Minnesota
    '10 ZR1
    #drivermod ???
    What gears do you have? Have you watched your fuel pressure when the injectors are supposedly maxing out? As mentioned might be racetronix and hot wire mod time
    Feb 2012
    Long Island, NY
    2001 Trans Am
    #drivermod ???
    A4?
    Feb 2012
    Long Island, NY
    2001 Trans Am
    i have 3:42 gears and the fuel pressure drops only when coming to a stop. the car kinds like surges and sometimes will stall
    Minnesota
    '10 ZR1
    A4?
    Spinnin' ain't winnin'
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    M/T DR's to the rescue! That alone cut my short time by .2+. Turned it into an insta-hook at the right stall speed...
    Minnesota
    '10 ZR1
    Quote Originally Posted by 67CamaroRSSS View Post
  1. fuel injector question
    By 1998 T/A in forum External Engine
    Last Post: 03-11-2015, 11:15 AM
  2. Fuel injector question
    By RichWS6 in forum Firebird / WS6
    Last Post: 04-09-2014, 12:42 PM
  3. Fuel Injector Question
    By sscamaro2000 in forum External Engine
    Last Post: 01-10-2009, 05:29 AM
  4. Bosch fuel injector question
    By koolaid_kid in forum LT1
    Last Post: 09-13-2006, 07:29 PM
  5. Fuel Injector Question
    By rbrack in forum External Engine
    Last Post: 02-28-2006, 06:53 PM
