Results 1 to 2 of 2
Thread: crane 1.8:1 rocker arms
04-20-2006, 05:28 AM #1Junior Member
- Jan 2006
- seabrook, tx
silver- 1998 z28 convertable
I want to get a set of Crane 1.8:1 "Quick Lift" rocker arms.
You can buy either just the rocker arms, or the rocker arms, push rods, guide plates, and studs as a kit. There is a $300 difference in price between the 2 options.
Is the kit realy required or will the stock studs and stuff work.
Thanks in advance
04-21-2006, 11:26 AM #2
you have to have all the other pieces to make them work. the rockers are adjustable. they require the shorter 7.250 pushrods, screw-in-studs, poly locks, and guideplates.
High-Ratio Rocker Arms - Off Your Rocker
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-19-2011, 02:50 PM -
Video dyno test of the the crane quick lift rocker arms
By powerjon in forum Multimedia SectionReplies: 5Last Post: 09-28-2007, 12:13 PM -
piston to valve clearence with crane cams quick lift rocker arms?
By Rob00Taws6 in forum External EngineReplies: 3Last Post: 06-22-2007, 02:19 PM -
By u69038 in forum Internal EngineReplies: 3Last Post: 04-21-2006, 11:30 AM -
Crane Gold 1.89 rocker arms F/S
By eviLS6 in forum Parts For Sale / TradeReplies: 0Last Post: 03-07-2006, 02:50 PM
