Results 1 to 1 of 1
Thread: Crane Gold 1.89 rocker arms F/S
03-07-2006, 02:50 PM #1eviLS6Guest
Used 3k miles
Crane 1.89 Gold Roller Rockers
guide plates, stud nuts, and hardened 7.25 inch pushrods that work in conjunction with the rockers arms.
Asking $380 shipped
I paid $670 for them new, the studs are missing, youll have to contact either VHP or cranecams to order those separately. You will also need the poly locks. VHP should be able to help with everything, the studs run $76 through Summit. I believe these are the correct ones according to cranecams, but you may want to double check to be sure.
http://store.summitracing.com/defau...ch.asp&N=400078
Heres a link to where I purchased everything new
http://www.vincihighperformance.com...S1MAINPAGE.HTML
Cool thing about these is they come off the seat at 1.89 and then settle to 1.79 when the valve is all the way open, so those concerned with P to V can effectively and safely increase the duration and lift events of a cam.
I still recommend checking P to V if the lift is in question. These are beautiful and stronger, and amazingly only 5 grams heavier a piece than stock stamped.
I prefer paypal.
High-Ratio Rocker Arms - Off Your Rocker
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 08-19-2011, 02:50 PM -
Video dyno test of the the crane quick lift rocker arms
By powerjon in forum Multimedia SectionReplies: 5Last Post: 09-28-2007, 12:13 PM -
piston to valve clearence with crane cams quick lift rocker arms?
By Rob00Taws6 in forum External EngineReplies: 3Last Post: 06-22-2007, 02:19 PM -
Crane 1.8:1 "Quick Lift" rocker arms
By u69038 in forum Internal EngineReplies: 3Last Post: 04-21-2006, 11:30 AM -
crane 1.8:1 rocker arms
By u69038 in forum General HelpReplies: 1Last Post: 04-21-2006, 11:26 AM
Edit Post
