04-02-2014, 09:28 AM #1Pontiac Builds Excitement
- Nov 2005
- NC
Sunset Orange Metallic- 2002 Pontiac TransAm WS6
Cleaning the backside of the rims
What would be a good way to remove the old brake dust and hardened stuff on the backside of my stock rims? I tried tar remover, simple green, brake clean, carburetor cleaner, ect... and nothing has really done that well. I'm not trying to strip/polish the rims, just clean the crap off of the backs.
Maybe someone has an idea of what will work and not damage the rims.
04-02-2014, 09:59 AM #2Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Ironx will help neutralize everything and make it easier to clean. But if its been on their a few years. Claying and other cleaners will help but it will take a full polishing to get rid of it all. Brake dust if not neutralized will etch into the surface and cause grooves were it will bind to it.
04-02-2014, 10:03 AM #3
Hiya,
Been there, done this and although my cleaning of the back of the rims is a pre-cursor to further
work with abrasive papers and flap wheels and stuff my initial cleaning is with acetone and a
scotchbrite.
If you don't want to scratch things then a fine one or a worn one and this is just enough "bite"
to loosen the crap with the acetone. As always start mild and work up so you may find that acetone
and a rough type of shop rag will do??!
Hope this helps.
Trev
04-02-2014, 11:56 AM #4
I was going to say that you'll probably need some type of solvent to really get that stuff off. Whatever you use, test it first in a small area before you go nuts on the whole back of the rim.
04-04-2014, 05:32 AM #5Pontiac Builds Excitement
- Nov 2005
- NC
Thanks for all the ideas, I kind of figured it was going to be difficult. I wonder if lacquer thinner would loosen the crud up?
I will try a few different chemicals/solvents and some fine abrasive or steel wool and see where that gets me.
Thanks again!
04-07-2014, 05:17 PM #611 years of bangin gears
- Jan 2009
- North Jersey
Lacquer thinner might work, but I don't know if it will stain the finish permanently. I have used brake cleaner and a wire brush to remove brake dust when I balance polished wheels using tape weights.
Cleaning Y2K rims back to new..?
By mammoth713 in forum Showcar and DetailingReplies: 19Last Post: 12-17-2019, 04:15 AM -
cleaning ws6 rims
By peteo101 in forum Showcar and DetailingReplies: 6Last Post: 03-18-2011, 09:02 PM -
cleaning aftermarket rims
By sirenformula350 in forum Wheels and TiresReplies: 8Last Post: 04-10-2008, 11:35 AM -
cleaning rims
By rajiv1998 in forum Showcar and DetailingReplies: 1Last Post: 11-09-2006, 03:48 PM -
Cleaning inside of rims
By TheKitchenSink in forum Showcar and DetailingReplies: 24Last Post: 09-24-2006, 04:50 PM
