Results 1 to 20 of 25
    KWK N NUF TheKitchenSink's Avatar
    Arlington Heights, Illinois
    2001 Trans Am WS6
    Cleaning inside of rims
    I just polished my calipers so my wheels are off the car. No better time to clean the inside of them then now. What is the best thing to use to get back to the rim instead of all the dirt/grime. I was using bleechwhite with some success but im looking for better. Any ideas? It needs to be something strong.
    Member ErikElvis's Avatar
    Feb 2006
    north east
    sunset orange
    02 SS M6
    bleachwhite worked fine for me. A stiff brush def helps too. I had a few years of "cakeage" that needed some hard scrubbing
    05 HEMI Ram, 96 Eclipse GST, 02 SS.
    2001 Trans Am WS6
    I was gonna try some engine degreaser but didnt know if thats something I wanted to be spraying on my rims or not. Ill have to try the simple green, the bleachwhite wasnt cutting it.
    2001 Trans Am WS6
    They are the stock rims, so I would assume so im not sure. I take it if they are its ok to spray degreaser on em? and just polish them afterwards?
    2001 Trans Am WS6
    alright thanks, Ill give it a try tomorrow. Ill try the simple green first and see what happens. Thanks for the help.
    Member 01camaross's Avatar
    Illinois,
    2001 camaross
    simple green should work and i used a bug rag to clean them with the simple green, just make sure to keep the finished side wet so no chemicals dry on them.
    Member Hawk241's Avatar
    UPSTATE NEW YORK
    2002 TransAm Firehawk
    Anyone delt with firehawk wheels, on the outside they are very good, however, closer look at the inside is crazy pitting, looks like a virus, its so bad..thought about wire wheeling the inside and then spraying it with clear coat, anyone have suggestions? Its a 2002, do you think it might be covered under some appearance waranty?
    you know, i did that with my 00 ws.6 rims. I scrubbed most of the lite stuff off with a brush and soap. Then i used a drill with a wire brush and used that to strip all the rest of it. Looked decent afterward, but 90k miles of shit and only about the last 35k worth came off ohwell.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Eagle 1 All Wheel and Tire Cleaner
    Looks like this:
    It works excellent - cleans off brake dust, dirt, grease off wheels like nothing, and won't harm clearcoat. My brake dust stained wheel brush looks like new after using it with the Eagle 1
    1 BAD ASS BOWTIE StangKiller615's Avatar
    Feb 2006
    Nashville Tn
    Black on Black
    Quote Originally Posted by TheKitchenSink View Post
    Have you tried the Meguiar's gold class all wheel cleaner? I use this often on my chrome wheels, and it works well.
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Do NOT use Castrol Super Clean, you may mess up the finish on the rim. If you ever want paint off something, spray some on the item, let set a few minutes, and rinse it off. Paint's gone.
    2002 Sunset Orange TransAm 6 spd.
    http://www.mustangmods.com/data/1327/dadsigpic2.jpg
    2001 Trans Am WS6
    Quote Originally Posted by Wesman View Post
    Looks like this:
    Thats what I use everytime I wash my car, I think that is what works the best. But the stuff on the inside is so caked on it didnt get everything I was looking for. Thing that worked the best was a pressure washer, it gave me the best results. Still not as clean as I want em, but a hell of a lot better.
    Junior Member 1SICZ's Avatar
    2002 35th Ann Z28
    Looks like this:
    yeah what he said
    John
    Too many mods too list......
    Feb 2006
    Nashville Tn
    Black on Black
    Try a steam cleaner.
    insert witty title here Blk00ws6's Avatar
    Georgetown, Oh
    2000 WS6
    I used an SOS pad on the inside. A putty knife to get the occasional asphalt rock out. Did ok. At least you can see the tiny grooves. On the outside I use Meguire's Hot Rims.
    If your wheels are very dirty just get a spray can of carb and choke cleaner,spray it on a rag NOT the rim and start wiping it will work.You will need a few rags that you do not care about,because you will tossing them in the trash.Then use some soap and water to clean the rim.Then wax or polish the rim.There you are all done.I did this and it will do the job.
    2001 Trans Am WS6
    Quote Originally Posted by Brianss1 View Post
    I've got some in the garage, I might have to try it.
    Jun 2006
    irving
    candy red
    98 Camaro Z28
    What about brake cleaner
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Try acetone.
    Lead Foot! WhiteLs1's Avatar
    Vegas
    99 Z28
    Simple Green
  1. Cleaning Y2K rims back to new..?
    By mammoth713 in forum Showcar and Detailing
    Last Post: 12-17-2019, 04:15 AM
  2. cleaning ws6 rims
    By peteo101 in forum Showcar and Detailing
    Last Post: 03-18-2011, 09:02 PM
  3. Cleaning inside of exhuast and cat... ?
    By grandkodiak in forum External Engine
    Last Post: 09-24-2008, 08:13 PM
  4. cleaning aftermarket rims
    Last Post: 04-10-2008, 11:35 AM
  5. cleaning rims
    By rajiv1998 in forum Showcar and Detailing
    Last Post: 11-09-2006, 03:48 PM
