    Mar 2014
    Weldon
    1998 Pontiac Firebird T/A
    Blower Motor Malfunction need help!
    98 trans am
    When I fire up the car the blower motor will work on and off on all different settings high and low. A buddy of mine removed said motor and hooked it up to a power source outside the car and it ran full blast no issues. Any idea what connection is the issue? We think it may be the connection that connects directly into the motor.But we dont know what it is called. Any thoughts tips and feedback is much appreciated!!!
    I would suspect the resistor assembly if that is how our blower motors operate. Other than that, maybe the BCM is the issue?
    Mar 2014
    Weldon
    Any tips on how to check if it is the resistor? And what is the BCM?
    BCM = Body control Module. It controls things like the power windows, radio, internal lighting and yes even some of the HVAC systems.
    I would look for the resisters first. Easier to get to and cheaper to fix. IIRC it is located under the radio in that center section, like in front of the counsel area.
    Mar 2014
    Weldon
    It is the resistor! How do I take it apart to replice the ends?? Or can I?
    Mar 2014
    Weldon
    To be clear it's just the connector
  1. Blower motor
    By az gt eater in forum General Help
    Last Post: 09-02-2014, 04:00 AM
  2. Blower Motor Issue: Continued
    By Jmmills92 in forum General Help
    Last Post: 03-20-2014, 06:50 AM
  3. blower motor problems
    By pewterz55 in forum General Help
    Last Post: 04-07-2011, 05:45 AM
  4. Blower motor not working.
    By bh400ex in forum General Help
    Last Post: 01-18-2010, 04:50 PM
  5. A/C Blower motor wires?
    By carls02tafirehawk in forum Stereo and Electronics
    Last Post: 07-29-2006, 01:43 PM
