Results 1 to 10 of 10
    Member pewterz55's Avatar
    Jul 2009
    chicago
    light pewter metallic
    1999 z28
    blower motor problems
    whats up guys/gals, im tryin to fix my g/fs blower motor. speeds 1-3 went out about a month ago but 4(high speed) still worked. but just last week four went out also. i looked it up online and found that many 2000 ford focuses have had this problem and they all just switched the blower motor resister and that fixed the problem. well i just replaced that today and still nothing. i figured if it was the blower motor itself with a working resister it would atleast hum and try and work with power going to it but there is no noise or anything. any ideas out there?
    Pittsburgh
    2008 Hummer H3
    Bad switch?
    Jul 2009
    chicago
    1999 z28
    hm yea maybe, just seems weird that the frist 3 went out at the same time then a couple weeks later the 4th speed goes too. i just hope the motor isnt bad cuz its a PITA to get in there to get it out
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by pewterz55 View Post
    I'd try to hook up a multimeter to the power inputs for the blower and then watch what it does while working the switch through the settings.
    That should help point to the switch if it is the switch.. Hope this helps.
    Jul 2009
    chicago
    1999 z28
    not a bad idea thanks smittro
    Pittsburgh
    2008 Hummer H3
    Thumbs up
    No prob, hopefully you can get to it enough to hook it up..
    Maybe an extra set of hands would help..
    Jul 2009
    chicago
    1999 z28
    well the problem is is that is located behind the glove box, so i have the box taken out already and my two arms can hardly fit in there let alone tools,flashlight etc. but like you said ill take a fluke to the prongs on the harness connecting to the motor
    Jul 2009
    chicago
    1999 z28
    thread from a while ago but just a fyi, in the ford focus it turned out to be the switch that i diagnosed easily with smittros method(thanks). but also the same thing happened with my old mans ford freestyle (same exact symptoms)but his car just turned out to be the blower motor resister. both cars blowers running perfectly now
    Pittsburgh
    2008 Hummer H3
    Sweet!
    Apr 2011
    syracuse ny
    2000 trans am
    I second the switch.
  1. Blower motor
    By az gt eater in forum General Help
    Last Post: 09-02-2014, 04:00 AM
  2. Blower Motor Issue: Continued
    By Jmmills92 in forum General Help
    Last Post: 03-20-2014, 06:50 AM
  3. Blower Motor Malfunction need help!
    Last Post: 03-13-2014, 04:06 PM
  4. Blower motor not working.
    By bh400ex in forum General Help
    Last Post: 01-18-2010, 04:50 PM
  5. A/C Blower motor wires?
    By carls02tafirehawk in forum Stereo and Electronics
    Last Post: 07-29-2006, 01:43 PM
